Inleiding
Ga naar stap 1 ↓Has debris found its way between the casing and the screen? Use this guide to remove and clean the screen.
As handling the display housing may damage the wire strip, use caution.
Wat je nodig hebt
Gereedschap
Spudger4.9
On the door's bottom edge, locate the gap between the external and internal screen covers.
Using a spudger (not shown), gently pry apart the external and internal covers until the sides start to separate.
Continue working your way along the edges of the phone, alternating sides, until the external cover can be easily removed.
