Ga door naar hoofdinhoud
How to check if iPod HDD is fine.
  1. How to check if iPod HDD is fine., Restart and boot your iPod to recovery mode.: stap 1, afbeelding 1 van 2 How to check if iPod HDD is fine., Restart and boot your iPod to recovery mode.: stap 1, afbeelding 2 van 2
    • Hold down the SELECT (middle) button and the MENU button to restart your iPod.
    • Then hold down the select (middle) button and the previous track button.
  2. How to check if iPod HDD is fine., Operating the recovery menu.: stap 2, afbeelding 1 van 3 How to check if iPod HDD is fine., Operating the recovery menu.: stap 2, afbeelding 2 van 3 How to check if iPod HDD is fine., Operating the recovery menu.: stap 2, afbeelding 3 van 3
    • Scroll your click wheel to IO (select with select)
    • Then Hard Drive
  3. How to check if iPod HDD is fine., Scanning the HD!: stap 3, afbeelding 1 van 2 How to check if iPod HDD is fine., Scanning the HD!: stap 3, afbeelding 2 van 2
    • Lastly, HDScan
    • Scan takes a while, wait.
  4. How to check if iPod HDD is fine., Conclusion.: stap 4, afbeelding 1 van 1
    • If you get a message "11ror!" your HDD is toast. RIP HDD ;(
    • Else, your HDD is fine!
Conclusie
To restart your iPod hold down the select (middle) button and the menu button.
19 andere personen hebben deze handleiding voltooid.
windowsio ROBLOX And More
709 Reputatie
1 Handleiding geschreven
5 opmerkingen
After holding down select and previous track buttons in Step 1, my iPod always shows a warning sign with www.apple.com/support/ipod Is there a way to get around this?
andrew.zellman - Antwoord
Dead hard drive then.
Cody Baxter -
If it's a red x then yes, your hard drive is dead.
To be completely honest reading this guide I did a really bad job of being professional. Sorry for the cringe guys.
windowsio ROBLOX And More -
I am able to get to the scanner, but my iPod boot loops before its able to finish. What would that mean?
CreeperDoolie - Antwoord
I've just ordered an iFlash for my iPod Classic and wondered if the hard drive in my iPod was getting bad, but this helped out a ton! I may even keep using my iPod until the drive dies. The menu is really useful and confirmed that I don't need to replace the battery either! Thanks a bunch for this guide!
Metabera - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 144
Afgelopen 30 dagen: 614
Altijd: 15,914
