Ga door naar hoofdinhoud
How to check Fujifilm FinePix S8200 for loose LCD connection
Wat je nodig hebt
  1. How to check Fujifilm FinePix S8200 for loose LCD connection, Batteries: stap 1, afbeelding 1 van 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. How to check Fujifilm FinePix S8200 for loose LCD connection: stap 2, afbeelding 1 van 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. How to check Fujifilm FinePix S8200 for loose LCD connection: stap 3, afbeelding 1 van 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: stap 4, afbeelding 1 van 3 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: stap 4, afbeelding 2 van 3 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: stap 4, afbeelding 3 van 3
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. How to check Fujifilm FinePix S8200 for loose LCD connection: stap 5, afbeelding 1 van 3 How to check Fujifilm FinePix S8200 for loose LCD connection: stap 5, afbeelding 2 van 3 How to check Fujifilm FinePix S8200 for loose LCD connection: stap 5, afbeelding 3 van 3
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. How to check Fujifilm FinePix S8200 for loose LCD connection: stap 6, afbeelding 1 van 1
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. How to check Fujifilm FinePix S8200 for loose LCD connection, How to check Fujifilm FinePix S8200 for loose LCD connection: stap 7, afbeelding 1 van 1
    • Fold back the LCD screen and check that the cable coming from the screen is securely fastened to the motherboard.
  8. How to check Fujifilm FinePix S8200 for loose LCD connection: stap 8, afbeelding 1 van 1
    • Fold the LCD screen back into the proper position.
Conclusie
Joseph Kelley
228 Reputatie
2 handleidingen geschreven
USF Tampa, Team 7-1, Remmell Winter 2015 Lid van USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 700
