Ga door naar hoofdinhoud
How to change the grips on a golf club
Wat je nodig hebt
  1. How to change the grips on a golf club, Grip: stap 1, afbeelding 1 van 2 How to change the grips on a golf club, Grip: stap 1, afbeelding 2 van 2
    • Tighten golf club on vice clamp. Align the golf club so that the club face is vertical.
    • Note: Make sure you place container underneath the grip to catch excess mineral spray in later steps.
  2. How to change the grips on a golf club: stap 2, afbeelding 1 van 2 How to change the grips on a golf club: stap 2, afbeelding 2 van 2
    • With the xacto knife cut the old grip off of the club.
    • Remove grip from club.
  3. How to change the grips on a golf club: stap 3, afbeelding 1 van 2 How to change the grips on a golf club: stap 3, afbeelding 2 van 2
    • Measure the amount of double-sided tape necessary to cover the area of your grip.
    • Place the tape on the club so that it is centered and an extra inch comes off the end of the club.
  4. How to change the grips on a golf club: stap 4, afbeelding 1 van 2 How to change the grips on a golf club: stap 4, afbeelding 2 van 2
    • Squirt mineral spirits on the tape.
    • Make sure you drench the tape in mineral spirits.
    • Note: it is safe to get mineral spirits on your skin, it is non-toxic.
  5. How to change the grips on a golf club: stap 5, afbeelding 1 van 3 How to change the grips on a golf club: stap 5, afbeelding 2 van 3 How to change the grips on a golf club: stap 5, afbeelding 3 van 3
    • While the tape still has mineral spray on it, quickly slide the grip all the way down.
  6. How to change the grips on a golf club: stap 6, afbeelding 1 van 1
    • Wait 1-2 hours for the mineral spray to dry.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Esteban Ortega
147 Reputatie
1 Handleiding geschreven
Cal Poly, Team 30-2, Green Spring 2015 Lid van Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 Leden
4 handleidingen geschreven
Één opmerking
Muy bueno. Gracias
Matias Doro Altan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 1,013
