Inleiding
In this video tutorial, I will show you how to calibrate a gimbal camera on a DJI Mavic Mini. This process is necessary after replacing the camera stabilizer, gimbal assembly, or changing the drone motherboard.
Download Programs for Calibration Gimbal :
- Python: https://www.python.org/
- PySerial: https://pypi.org/project/pyserial/#files
- GitHub: https://github.com/o-gs/dji-firmware-too...
- 7-zip: https://7-zip.org/
First script to run calibration
- py comm_og_service_tool.py --port com pcode GimbalCalib JointCoarse
Second gimbal calibration script
- py comm_og_service_tool.py --port com pcode GimbalCalib LinearHall
Video-instructies
Bijna klaar!
To reassemble your device, follow these instructions.
Conclusie
6 opmerkingen
Does this work for the dji mini se? As I do not see a pcode in the list.
Joshua Dockery - Antwoord
Thank you for your video, for me it gets stuck in the "Info: The Gimbal will slowly move through all positions in all axes," and not responding.. any ideas? Thank you.
Βασίλης Τριανταφύλλου - Antwoord
Gimbal still is facing to the left
Luis Royo - Antwoord
When I put in the py setup.py install command, I get an error message. File
not found or something similar. I’ve tried redownloading and tried different versions of py and pyserial 3.5. Any advice?
Dji mini - Antwoord
After I download and unzip/install everything, go to the CMD screen as administrator and type cd/ cd dji, everything works until I enter py setup.py install. Then I get this error.
ModuleNotFoundError: No module named ‘setup tools’
ModuleNotFoundError: No module named ‘distutils’
What am I doing wrong?
Dji mini - Antwoord
