Inleiding
If your brakes are slowing you down too fast or not fast enough, this guide can help remedy this problem.
Wat je nodig hebt
While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
Bijna klaar!
You may need to repeat this process until your desired tension is achieved (trial and error).
Conclusie
