Ga door naar hoofdinhoud
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: stap 1, afbeelding 1 van 2 How to adjust Razor A steering column, How to adjust Razor A steering column: stap 1, afbeelding 2 van 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: stap 2, afbeelding 1 van 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Jordyn
565 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-13, Amido Fall 2012 Lid van Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Leden
10 handleidingen geschreven
8Gids Commentaar
what move it with your hands? - didn't help
Heather McCasland - Antwoord
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - Antwoord
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Antwoord
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 85
Altijd: 43,292
