Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn off the phone. Press and hold at the same time Volume UP,Home and Power keys. When you see Galaxy logo release the Power key but continue to hold the Volume Up key and the Home key.
Release them when the Android System Recovery screen appears. Use Volume Up/Down keys for navigation and Power On key for OK. Choose "wipe cache partition", "Yes -- delete all user data", "reboot system now".
283 andere personen hebben deze handleiding voltooid.
31 opmerkingen
Here my recommendation is a data eraser named Android Data Eraser, which can erase all Android data including contacts, messages, call history, apps, system setting, photo, video, etc. Indeed, Android Data Eraser worth trusting and it makes the work more effective. What you need is a windows computer. One single click and data deletion finish.
easy to follow instructions but does not work have done it 3 times now and get to a step which requires to do a factory reset. Phone the automatically switches off and loses connection with program and have to start all over again. Goes round in circles with a factory reset the only result - and you can do that without downloading the program.
why would you bother when you can factory reset in 1 min???
Deleted data from samsung phone are recoverable with Coolmuster Samsung Recovery software. But you need to follow special steps as droid phone`s memory is not accessible easily.
Hi Can the software recover my calendar after I mistakenly did a factory wipe?
