Ga door naar hoofdinhoud
How to Wash and Dry a Patagonia Down Jacket
Wat je nodig hebt
  1. How to Wash and Dry a Patagonia Down Jacket, How to Wash and Dry a Patagonia Down Jacket: stap 1, afbeelding 1 van 3 How to Wash and Dry a Patagonia Down Jacket, How to Wash and Dry a Patagonia Down Jacket: stap 1, afbeelding 2 van 3 How to Wash and Dry a Patagonia Down Jacket, How to Wash and Dry a Patagonia Down Jacket: stap 1, afbeelding 3 van 3
    • Lay your jacket out and zip up all the zippers.
    • If your jacket has hook-and-loop tape, fasten it closed.
    • Don't forget to check the pockets for any treasures or love notes you may have forgotten.
    • Place the jacket in your washing machine.
  2. How to Wash and Dry a Patagonia Down Jacket: stap 2, afbeelding 1 van 3 How to Wash and Dry a Patagonia Down Jacket: stap 2, afbeelding 2 van 3 How to Wash and Dry a Patagonia Down Jacket: stap 2, afbeelding 3 van 3
    • Add technical wash specifically designed for down garments.
    • Each brand of technical wash is different, so you'll need to read the label on your bottle to know how much to add.
  3. How to Wash and Dry a Patagonia Down Jacket: stap 3, afbeelding 1 van 3 How to Wash and Dry a Patagonia Down Jacket: stap 3, afbeelding 2 van 3 How to Wash and Dry a Patagonia Down Jacket: stap 3, afbeelding 3 van 3
    • Set the load size on the washing machine to small.
    • Set the water temperature on the washing machine to cold/cold.
    • Run the washing machine on a gentle or normal wash cycle.
  4. How to Wash and Dry a Patagonia Down Jacket: stap 4, afbeelding 1 van 1
    • Leave the jacket in the washing machine and run the rinse cycle a second time.
  5. How to Wash and Dry a Patagonia Down Jacket: stap 5, afbeelding 1 van 3 How to Wash and Dry a Patagonia Down Jacket: stap 5, afbeelding 2 van 3 How to Wash and Dry a Patagonia Down Jacket: stap 5, afbeelding 3 van 3
    • Remove the jacket from the washing machine and place it in the dryer.
    • If you don't have a dryer, or would like to go a more environmentally friendly route, line dry your jacket.
    • Add a couple of tennis balls to the dryer.
    • The tennis balls will bounce around as the dryer tumbles, preventing the down from clumping.
  6. How to Wash and Dry a Patagonia Down Jacket: stap 6, afbeelding 1 van 2 How to Wash and Dry a Patagonia Down Jacket: stap 6, afbeelding 2 van 2
    • Set the dryer on a low-heat setting with a normal dry-cycle time.
    • Start the dryer.
    • It may take more than one cycle on the dryer to completely dry your jacket. If so, leave the heat on low and dry for a second cycle.
Eindstreep
12 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.014 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
3 opmerkingen
The NikWax wash stuff says to use a front loading washer. Is that really necessary? Or are they just messing with me. =)
jotepka - Antwoord
Front loading washers are gentler on clothes than top loaders so less chance of damaging relatively delicate down jackets.
Pete -
Inexpensive and warm down jackets have long since become part of our wardrobe. And almost every jacket has a warning label prohibiting wash and dry it at home.But enterprising housewives long found a way to wash down jackets at home. It turns out that it is not so difficult if you know some tricks. Here you will find tips how to wash down jacket in the washing machine and by hand https://pinkycloud.com/how-to-wash-a-dow....
It is also very important to know how to store down jackets, it very much depends on how long you will wear it http://triplefatgoose.com/blog/how-to-ta... Here are details and even more
Dana Lawler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 43
Afgelopen 7 dagen: 212
Afgelopen 30 dagen: 1,133
Altijd: 145,606
