Ga door naar hoofdinhoud
How to Wash and Dry Patagonia Sweater
Wat je nodig hebt
  1. How to Wash and Dry Patagonia Sweater, How to Wash and Dry Patagonia Sweater: stap 1, afbeelding 1 van 3 How to Wash and Dry Patagonia Sweater, How to Wash and Dry Patagonia Sweater: stap 1, afbeelding 2 van 3 How to Wash and Dry Patagonia Sweater, How to Wash and Dry Patagonia Sweater: stap 1, afbeelding 3 van 3
    • Fill the sink with cool water.
    • Never wash a sweater in hot water as it can cause the sweater to shrink.
    • Add some gentle liquid detergent to the water.
    • Each brand of detergent is different, so you'll need to read the label on your bottle to know how much to add. For most soaps, a tablespoon is plenty.
  2. How to Wash and Dry Patagonia Sweater: stap 2, afbeelding 1 van 3 How to Wash and Dry Patagonia Sweater: stap 2, afbeelding 2 van 3 How to Wash and Dry Patagonia Sweater: stap 2, afbeelding 3 van 3
    • Mix the soap into the water with your hand.
  3. How to Wash and Dry Patagonia Sweater: stap 3, afbeelding 1 van 2 How to Wash and Dry Patagonia Sweater: stap 3, afbeelding 2 van 2
    • Submerge the sweater in the soapy water.
    • Gently press down to make sure that the entire sweater is in the water.
    • Allow the sweater to soak for 15-20 minutes.
  4. How to Wash and Dry Patagonia Sweater: stap 4, afbeelding 1 van 2 How to Wash and Dry Patagonia Sweater: stap 4, afbeelding 2 van 2
    • Drain the sink and rinse the sweater, squeezing it gently in your hands to release all the extra soap and water.
    • Never twist or wring out a sweater as this can distort the fibers.
  5. How to Wash and Dry Patagonia Sweater: stap 5, afbeelding 1 van 3 How to Wash and Dry Patagonia Sweater: stap 5, afbeelding 2 van 3 How to Wash and Dry Patagonia Sweater: stap 5, afbeelding 3 van 3
    • Place a towel on a waterproof surface.
    • Lay the sweater out on the towel.
    • Gently lay the sweater flat, lightly stretching it to its proper size.
    • Do not over stretch the sweater.
    • Lay the sleeves out flat, gently stretching them to their proper size.
    • Allow the sweater to lay undisturbed until it is dry.
    • Never hang-dry a sweater, as it can strech or warp the fibers.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Brittany McCrigler
89.017 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
2 opmerkingen
It was a very good experience, thank you. <a href="http://playfnfgame.com/">fnf</a>
GAME ROCCO - Antwoord
It was a very good experience, thank you. vex7
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 5,486
