Ga door naar hoofdinhoud
How to Wash a Waterproof Jacket
  1. How to Wash a Waterproof Jacket, How to Wash a Waterproof Jacket: stap 1, afbeelding 1 van 2 How to Wash a Waterproof Jacket, How to Wash a Waterproof Jacket: stap 1, afbeelding 2 van 2
    • Inspect the damage.
    • Brush off any loose dirt or debris.
    • If you've got a particularly stubborn stain, check out Patagonia's Product Care guide.
  2. How to Wash a Waterproof Jacket: stap 2, afbeelding 1 van 3 How to Wash a Waterproof Jacket: stap 2, afbeelding 2 van 3 How to Wash a Waterproof Jacket: stap 2, afbeelding 3 van 3
    • Zip the main zipper of the jacket all the way up.
  3. How to Wash a Waterproof Jacket: stap 3, afbeelding 1 van 3 How to Wash a Waterproof Jacket: stap 3, afbeelding 2 van 3 How to Wash a Waterproof Jacket: stap 3, afbeelding 3 van 3
    • Loosen any drawstrings and undo any cuffs.
    • Unzip the pocket zippers.
    • Now is a good time to pull any hidden treasures out of your pockets.
  4. How to Wash a Waterproof Jacket: stap 4, afbeelding 1 van 2 How to Wash a Waterproof Jacket: stap 4, afbeelding 2 van 2
    • Place your jacket in the washing machine.
    • Add laundry soap.
    • You can use soap specifically formulated to clean waterproof clothing or gentle nondetergent laundry soap.
    • Do not use soap containing bleach, fabric softeners, enzymes, stain removers, perfumes or whiteners.
  5. How to Wash a Waterproof Jacket: stap 5, afbeelding 1 van 3 How to Wash a Waterproof Jacket: stap 5, afbeelding 2 van 3 How to Wash a Waterproof Jacket: stap 5, afbeelding 3 van 3
    • Set the load size to small.
    • Set the water temperature to warm/cold.
    • Run the washer on a regular or permanent press cycle setting.
  6. How to Wash a Waterproof Jacket: stap 6, afbeelding 1 van 2 How to Wash a Waterproof Jacket: stap 6, afbeelding 2 van 2
    • Once the cycle is completed, run the washer again on the rinse cycle to flush any remaining soap out of the jacket.
    • Take your jacket out of the washer.
    • Inspect your jacket.
    • If it looks clean and residue-free, go ahead and follow our guide to dry your jacket.
    • If your jacket looks or feels funny, place it back in the washer and run another rinse cycle.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
9 opmerkingen
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
Albert Daniel - Antwoord
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Rachel - Antwoord
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
Sarah Geers - Antwoord
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
choffman - Antwoord
They absolutely will replace it or give you store credit.
Nathan Keirn -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 65
Afgelopen 30 dagen: 346
Altijd: 52,610
