Ga door naar hoofdinhoud
How to Use a Needle Threader
Wat je nodig hebt
  1. How to Use a Needle Threader, How to Use a Needle Threader: stap 1, afbeelding 1 van 2 How to Use a Needle Threader, How to Use a Needle Threader: stap 1, afbeelding 2 van 2
    • Take the needle threader in one hand, and the needle in your other hand.
    • Insert the wire loop on the needle threader through the eye of the needle.
  2. How to Use a Needle Threader: stap 2, afbeelding 1 van 3 How to Use a Needle Threader: stap 2, afbeelding 2 van 3 How to Use a Needle Threader: stap 2, afbeelding 3 van 3
    • Hold both the needle threader and needle in one hand, while keeping the loop of wire on the needle threader through the eye of the needle.
    • Insert your thread through the loop of wire on the needle threader.
    • Pull the thread through the loop so that you have a tail of least a few inches in length.
  3. How to Use a Needle Threader: stap 3, afbeelding 1 van 2 How to Use a Needle Threader: stap 3, afbeelding 2 van 2
    • Fold the tail over to meet the other thread.
    • Hold both lengths of thread together.
  4. How to Use a Needle Threader: stap 4, afbeelding 1 van 3 How to Use a Needle Threader: stap 4, afbeelding 2 van 3 How to Use a Needle Threader: stap 4, afbeelding 3 van 3
    • While holding both threads, pull the wire loop of the needle threader out of the eye of the needle.
    • Once the wire loop is out of the eye, release the tail end of the thread.
    • Pull the needle threader off the thread. This will bring the tail end through.
  5. How to Use a Needle Threader: stap 5, afbeelding 1 van 3 How to Use a Needle Threader: stap 5, afbeelding 2 van 3 How to Use a Needle Threader: stap 5, afbeelding 3 van 3
    • Pull the tail end of the thread until both threads are equal in length.
    • Holding both lengths of thread together, tie a knot near the end and pull it tight.
    • This will trap the needle in the loop of thread and allow you to sew with doubled thread. If you prefer to sew with a single thread, tie a knot in only one of the threads, not both.
Eindstreep
71 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.014 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
18 opmerkingen
thank you for this
it helped me with
sewing project
Swathika E - Antwoord
For years I have been doing this the hard way. I had no idea what the threader was. I have thrown so many away not knowing what they were. Thank you so much. You've made what i enjoy doing (sewing projects), even more enjoyable.
Shannon B, 01/06/2016
Shannon Beecham - Antwoord
Though I had a needle threader but didn't know how to use it ?
Your guidelines really helped me. Thanks a lot.
vickysos - Antwoord
Thank you. My automatic needle threader on sewing machine is off track and I'm not in the mood to locate online how to fix/correct it today. I had plenty of handheld and long neck serger needle threaders in my stash and couldn't figure out how to thread my needle on sewing machine with the long neck threader, but you helped me with that, thanks.
Bonita W - Antwoord
Thank you you are a Life saver!!!!
ciaaratpaen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 120
Afgelopen 7 dagen: 854
Afgelopen 30 dagen: 4,141
Altijd: 519,407
