Inleiding
You've created an amazing object on the Maker Bot software, and now it's time to print your objects. Follow these steps before you load your file into the 3D printer.
Make sure the filament is full
Pick the side you want to extrude from (You will need to input this information when you prepare your file)
Use the spray cleaner and paper towels to clean any leftover oil from the platform (Oil buildup may cause the plastic to stick)
Press the menu button and scroll through the options
Click the Utilities option under the option box
Select Level Build Plate option
The plate on the maker bot must be made perfectly level
Turn the front leveling knob to change the angle from front to back
Turn the right knob to change the angle from left to right
Press the "Begin Set-up" button on the control panel to start the process of making sure the plate is level
Slip a business card between the extruder and the plate, as extruder pauses at the four waypoints on the plate
On the control panel select Start Extrusion
Once you see filament start to come out of the tip, select Stop Extrusion on the control panel
Use the dial and select Test File 1 for a dragon and Test File 2 for a street cone
Push the dial and you will be taken to a file info page
Select Print
When the print is done, you should have a 1/2" plastic dragon or pyramid
Let the object cool before removing it
Notice the details of the object, if something does not look right, you should repeat the setup before you print off your design
If the test object looks perfect then it is time to print off your design
Insert a thumb drive that has the .makerbot file you want printed into the USB port on the right of the Control Panel
Select Upload File on the LCD Panel
The LCD panel will display all compatible files on the thumb drive
Select the file that you want to upload to the MakerBot
Repeat step 6 selecting the .makerbot file you want to print
When the object has cooled remove it from the 3D printer and admire it deeply
3 andere personen hebben deze handleiding voltooid.
