Ga door naar hoofdinhoud
How to Unclog an Epson ET-2760 Printhead
Wat je nodig hebt
  1. How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: stap 1, afbeelding 1 van 2 How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: stap 1, afbeelding 2 van 2
    • Begin a print of any kind, or a nozzle check.
    • Once the print has begun, pull the power cable out mid-print.
  2. How to Unclog an Epson ET-2760 Printhead: stap 2, afbeelding 1 van 2 How to Unclog an Epson ET-2760 Printhead: stap 2, afbeelding 2 van 2
    • Open the printer, then pull out the half-printed paper through the slot.
    • Place a thick paper towel or rag under the printhead.
  3. How to Unclog an Epson ET-2760 Printhead: stap 3, afbeelding 1 van 3 How to Unclog an Epson ET-2760 Printhead: stap 3, afbeelding 2 van 3 How to Unclog an Epson ET-2760 Printhead: stap 3, afbeelding 3 van 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Unclip the two white plastic clips.
    • Lift the top cover off of the printhead.
  4. How to Unclog an Epson ET-2760 Printhead: stap 4, afbeelding 1 van 1
    • Unclip the four ink cartridges from the printhead by pulling the small tabs on top of the cartridges.
    • Be sure not to disconnect the ink lines from the cartridges. Simply set the connected cartridges to the side of the printhead.
  5. How to Unclog an Epson ET-2760 Printhead: stap 5, afbeelding 1 van 2 How to Unclog an Epson ET-2760 Printhead: stap 5, afbeelding 2 van 2
    • Fill a syringe with printhead cleaning solution and place the syringe tip over the holes left by the cartridges.
  6. How to Unclog an Epson ET-2760 Printhead: stap 6, afbeelding 1 van 1
    • Begin to flush the manufacturer's recommended amount of solution through each hole onto the paper towel.
    • If necessary, swap out the paper towel in between flushes to prevent any solution from entering the printer.
  7. How to Unclog an Epson ET-2760 Printhead: stap 7, afbeelding 1 van 1
    • Remove the paper towel from under the printhead.
  8. How to Unclog an Epson ET-2760 Printhead: stap 8, afbeelding 1 van 3 How to Unclog an Epson ET-2760 Printhead: stap 8, afbeelding 2 van 3 How to Unclog an Epson ET-2760 Printhead: stap 8, afbeelding 3 van 3
    • Reattach each ink cartridge into their original positions.
    • Reattach the two printhead cover clips back onto the printhead.
    • Screw the single screw back into place with a Phillips #0 screwdriver.
  9. How to Unclog an Epson ET-2760 Printhead: stap 9, afbeelding 1 van 1
    • Perform an automatic cleaning to ensure that any ink residue is removed.
Conclusie
Enjoy your clean printhead!
16 andere personen hebben deze handleiding voltooid.
Jack Buttry
475 Reputatie
1 Handleiding geschreven
30 opmerkingen
Simple but to the point tutorial that detailed every step including the tools and supplies needed. Photos helped tremendously too. Thank you.
Mark DiRollo - Antwoord
Where do I find out the "manufacturer's recommended amount of solution" per flush?
Stelios Makrinos - Antwoord
Usually it's 5ml
Casper Hon -
But it seems that ink isn't even getting to my yellow and blue heads. At least, the test print shows no yellow or blue at all.
How can I get at the exit (valves?) on the ink storage tanks to make sure they're clear -- without breaking the printer?
Thanks!
warble58 - Antwoord
Me too! No yellow or blue coming through.
Tracy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 59
Afgelopen 7 dagen: 431
Afgelopen 30 dagen: 1,522
Altijd: 77,929
