Ga door naar hoofdinhoud
How to Unclog a Sink
Wat je nodig hebt
  1. How to Unclog a Sink, How to Unclog a Sink: stap 1, afbeelding 1 van 3 How to Unclog a Sink, How to Unclog a Sink: stap 1, afbeelding 2 van 3 How to Unclog a Sink, How to Unclog a Sink: stap 1, afbeelding 3 van 3
    • Begin by filling the sink halfway full with water.
    • Pump the plunger rapidly for 30 seconds.
    • Do NOT break seal between plunger and drain.
    • Repeat this process 4 to 6 times.
    • Wait 20 min before proceeding to the next step. This will allow some debris to flow down the pipes.
    • If the sink is equipped with a spillover (a hole in the side wall, next to the top edge), you should cover it with a paper towel or kitchen towel while pumping the plunger with the other hand. Otherwise the pressure, that you create by pumping, would be released via the spillover immediately, possibly throwing dirt into your sink.
    • If you wish to pump with both hands, you may want to ask somebody for help, to cover the spillover.
  2. How to Unclog a Sink: stap 2, afbeelding 1 van 2 How to Unclog a Sink: stap 2, afbeelding 2 van 2
    • Place a bucket below the P-trap .
    • The curved white pipe is called the P-trap.
    • These next few steps may get a bit messy. Proceed with caution.
  3. How to Unclog a Sink: stap 3, afbeelding 1 van 3 How to Unclog a Sink: stap 3, afbeelding 2 van 3 How to Unclog a Sink: stap 3, afbeelding 3 van 3
    • Carefully untwist slip nuts by hand.
    • If you are unable to remove by hand, use a slip joint plier to remove the slip nuts.
    • The nuts at the ends of the P-trap are called slip nuts.
  4. How to Unclog a Sink: stap 4, afbeelding 1 van 3 How to Unclog a Sink: stap 4, afbeelding 2 van 3 How to Unclog a Sink: stap 4, afbeelding 3 van 3
    • Use a small wire brush to clean the P-trap.
    • You may want to clean the connecting pipes with the wire brush as well.
  5. How to Unclog a Sink: stap 5, afbeelding 1 van 3 How to Unclog a Sink: stap 5, afbeelding 2 van 3 How to Unclog a Sink: stap 5, afbeelding 3 van 3
    • Carefully rinse the P-trap with hot water.
    • Do NOT rinse the P-trap in the sink you are working on because there is no connecting pipe to catch the water.
  6. How to Unclog a Sink: stap 6, afbeelding 1 van 3 How to Unclog a Sink: stap 6, afbeelding 2 van 3 How to Unclog a Sink: stap 6, afbeelding 3 van 3
    • Reattach the P-trap.
  7. How to Unclog a Sink: stap 7, afbeelding 1 van 3 How to Unclog a Sink: stap 7, afbeelding 2 van 3 How to Unclog a Sink: stap 7, afbeelding 3 van 3
    • Pour 1/2 cup of baking soda down the drain.
    • Pour 1/2 cup of distilled white vinegar down the drain.
    • Quickly cover the drain with a drain stopper.
    • This keeps the reaction in the pipes.
  8. How to Unclog a Sink: stap 8, afbeelding 1 van 2 How to Unclog a Sink: stap 8, afbeelding 2 van 2
    • As soon as the fizzing stops, pour another 1/2 cup of white distilled vinegar down the drain.
    • Cover again with a drain stopper.
    • Let the sink sit for 20 min.
  9. How to Unclog a Sink: stap 9, afbeelding 1 van 3 How to Unclog a Sink: stap 9, afbeelding 2 van 3 How to Unclog a Sink: stap 9, afbeelding 3 van 3
    • Boil 1 gallon of water with a boiler.
    • The boiler will get hot. Handle with care.
    • Pour the boiling water down the sink to flush out any remaining debris.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Daniel Sanchez
308 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-2, Green Fall 2015 Lid van Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 42
Altijd: 4,167
