Do you have a clogged sink? Do you not know what is wrong with it? Use this guide to solve your problem. If your sink becomes unclogged after step 1 or step 6, then you do not need to continue following the guide. But it is highly recommended that you finish the guide completely to ensure your sink is completely unclogged.
Begin by filling the sink halfway full with water.
Pump the plunger rapidly for 30 seconds.
Do NOT break seal between plunger and drain.
Repeat this process 4 to 6 times.
Wait 20 min before proceeding to the next step. This will allow some debris to flow down the pipes.
Place a bucket below the P-trap .
The curved white pipe is called the P-trap.
These next few steps may get a bit messy. Proceed with caution.
Carefully untwist slip nuts by hand.
If you are unable to remove by hand, use a slip joint plier to remove the slip nuts.
The nuts at the ends of the P-trap are called slip nuts.
Pour 1/2 cup of baking soda down the drain.
Pour 1/2 cup of distilled white vinegar down the drain.
Quickly cover the drain with a drain stopper.
This keeps the reaction in the pipes.
As soon as the fizzing stops, pour another 1/2 cup of white distilled vinegar down the drain.
Cover again with a drain stopper.
Let the sink sit for 20 min.
Boil 1 gallon of water with a boiler.
The boiler will get hot. Handle with care.
Pour the boiling water down the sink to flush out any remaining debris.
Deze handleiding insluiten
Kies een formaat en kopieer de code hieronder om deze handleiding als een kleine widget op je website of forum in te sluiten.
Enkele stap
Volledige handleiding
Klein - 600px
Middelgroot - 800px
Groot - 1200px
Voorbeeld
