Ga door naar hoofdinhoud
How to Unclog a Sink without Harsh Chemicals
Wat je nodig hebt
  1. How to Unclog a Sink without Harsh Chemicals, How to Unclog a Sink without Harsh Chemicals: stap 1, afbeelding 1 van 1
    • Measure two cups of tap water.
    • Pour the tap water into a tea kettle and heat the water until it boils.
    • Boiling water may cause burns. Handle with care. Turn stove off after use.
    • Slowly pour boiling water down the clogged drain.
    • This is to avoid splash back and possible injury.
  2. How to Unclog a Sink without Harsh Chemicals: stap 2, afbeelding 1 van 2 How to Unclog a Sink without Harsh Chemicals: stap 2, afbeelding 2 van 2
    • Measure one cup of baking soda.
    • Pour baking soda into a large mixing bowl.
  3. How to Unclog a Sink without Harsh Chemicals: stap 3, afbeelding 1 van 3 How to Unclog a Sink without Harsh Chemicals: stap 3, afbeelding 2 van 3 How to Unclog a Sink without Harsh Chemicals: stap 3, afbeelding 3 van 3
    • Measure one cup of vinegar.
    • Pour vinegar into the bowl with the baking soda.
    • Alternatively, mix in one cup of lemon juice as a substitution for the vinegar.
    • Do not use both vinegar and lemon juice.
    • Use a spatula to mix the contents until they form a paste.
  4. How to Unclog a Sink without Harsh Chemicals: stap 4, afbeelding 1 van 1
    • Pour the combination down the drain using a spatula.
  5. How to Unclog a Sink without Harsh Chemicals: stap 5, afbeelding 1 van 1
    • Measure two additional cups of tap water.
    • Allow the water to drain completely.
    • Run the tap for approximately 5 - 10 minutes.
    • It might take more than one attempt to clear the clog. Repeat this procedure as needed.
Eindstreep
Casper Savoie
124 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 452
