Ga door naar hoofdinhoud
How to Unclog a Penn-Plax Under Gravel Aquarium Filter
Wat je nodig hebt
  1. How to Unclog a Penn-Plax Under Gravel Aquarium Filter, How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 1, afbeelding 1 van 2 How to Unclog a Penn-Plax Under Gravel Aquarium Filter, How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 1, afbeelding 2 van 2
    • Locate your underground filter.
    • Underground filters are usually on the right or left side of the aquarium.
  2. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 2, afbeelding 1 van 3 How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 2, afbeelding 2 van 3 How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 2, afbeelding 3 van 3
    • Use the fish net to remove fish from your fish tank.
    • The size of your fish net differs on how big your fish is. Use small, medium, or big size fish nets accordingly.
    • Catch the fish with the help of the fish net.
    • Add some water from the aquarium to a separate container large enough to hold the fish.
    • Move the fish to the container to continue the cleaning process.
  3. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 3, afbeelding 1 van 2 How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 3, afbeelding 2 van 2
    • Grab your underwater vacuum.
    • Underwater vacuums help to remove debris (waste products) from above the gravel. It collects the debris and pumps it out with the water.
    • Keep a bucket at a certain distance from the vacuum so water can easily flow.
  4. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 4, afbeelding 1 van 2 How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 4, afbeelding 2 van 2
    • Insert your underwater vacuum at the top of the aquarium.
    • Using upward and downward movements, hold your vacuum while it is inside the water.
    • Once the water starts flowing from the aquarium to the bucket, move your vacuum on top of the gravel to remove the debris.
  5. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 5, afbeelding 1 van 1
    • Dispose of the collected water mixed with the debris.
    • If the water overflows, remove the vacuum from the aquarium. This will stop the flow of water.
  6. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 6, afbeelding 1 van 1
    • Grab the filter pipe and carefully remove it from the tank.
  7. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 7, afbeelding 1 van 1
    • Completely take out the filter to prepare for the cleaning process.
  8. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 8, afbeelding 1 van 3 How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 8, afbeelding 2 van 3 How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 8, afbeelding 3 van 3
    • Rotate the pipe counter-clockwise to detach the pipe.
    • Do not apply too much force. A little twist will work perfectly.
  9. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 9, afbeelding 1 van 2 How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 9, afbeelding 2 van 2
    • Use a scrubber to remove stuck debris from the pipe and filter base.
    • A new toothbrush works as the ideal scrubber.
    • After scrubbing, wash thoroughly.
    • Scrub gently; too much pressure will break the base of the filter.
  10. How to Unclog a Penn-Plax Under Gravel Aquarium Filter: stap 10, afbeelding 1 van 1
    • Reassemble the filter by inserting the pipe in the lock and rotating it clockwise.
    • Place the filter back in the aquarium.
    • Make sure to cover it with the gravel as shown in Step 1.
Conclusie
The filter is now cleaned and reassembled in the aquarium and ready for normal use. We recommend cleaning the filter once every month (four weeks) to maintain a desired living condition for your fish.
Aman Lama Thokkar
181 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 711
