Inleiding
You may think your Keurig is broken and done for good, but it may just be clogged. Use this guide to unclog your Keurig coffee brewer in just a few easy steps. All you'll need is your coffee brewer, a paperclip, a bottle of white vinegar and approximately 30 minutes.
Wat je nodig hebt
Fill the water tank with a half water-half vinegar solution.
Run the water-vinegar solution through the machine until you have emptied the tank.
Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
