Ga door naar hoofdinhoud
How to Tie a Tie: Pratt
Wat je nodig hebt
  1. How to Tie a Tie: Pratt, Preparation: stap 1, afbeelding 1 van 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Pratt: stap 2, afbeelding 1 van 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Pratt, Tying: stap 3, afbeelding 1 van 1
    • Take the active end and cross it under the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Pratt: stap 4, afbeelding 1 van 1
    • Lift the active end up, so that it is now pointing up.
  5. How to Tie a Tie: Pratt: stap 5, afbeelding 1 van 2 How to Tie a Tie: Pratt: stap 5, afbeelding 2 van 2
    • Pull the active end down through the loop around your neck, so that it is now pointing down and to the left.
  6. How to Tie a Tie: Pratt: stap 6, afbeelding 1 van 1
    • Cross the active end over the front of the knot, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 8.
  7. How to Tie a Tie: Pratt: stap 7, afbeelding 1 van 1
    • Pull the active end up through the neck loop, so that it is now pointing up.
  8. How to Tie a Tie: Pratt: stap 8, afbeelding 1 van 2 How to Tie a Tie: Pratt: stap 8, afbeelding 2 van 2
    • Pull the active end down through the wrap you created in step 6 (see second picture).
  9. How to Tie a Tie: Pratt, Finishing: stap 9, afbeelding 1 van 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  10. How to Tie a Tie: Pratt: stap 10, afbeelding 1 van 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  11. How to Tie a Tie: Pratt: stap 11, afbeelding 1 van 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Conclusie
Congratulations! You've successfully tied the Pratt knot!
3 andere personen hebben deze handleiding voltooid.
Wes
514 Reputatie
2 handleidingen geschreven
The Electric Warthogs Lid van The Electric Warthogs
Community
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 17
Altijd: 552
