Ga door naar hoofdinhoud
How to Tie a Tie: Half-Windsor
Wat je nodig hebt
  1. How to Tie a Tie: Half-Windsor, Preparation: stap 1, afbeelding 1 van 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Half-Windsor: stap 2, afbeelding 1 van 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: The narrow end of the tie should be around the height of your belly button or a little higher. It may need to be adjusted for personal height.
  3. How to Tie a Tie: Half-Windsor, Tying: stap 3, afbeelding 1 van 1
    • Take the active end and cross it over the narrow end, so it is pointing to the left.
    • Note: Be sure that the tie always lays flat so that there are no twists in the fabric.
  4. How to Tie a Tie: Half-Windsor: stap 4, afbeelding 1 van 1
    • Cross the active end underneath the narrow end, so it is now pointing to the right.
  5. How to Tie a Tie: Half-Windsor: stap 5, afbeelding 1 van 1
    • Lift the active end up over the right side of the neck loop, so it is pointing up.
  6. How to Tie a Tie: Half-Windsor: stap 6, afbeelding 1 van 1
    • Pull the active end down through the loop around your neck so that it is pointing down and to the left.
  7. How to Tie a Tie: Half-Windsor: stap 7, afbeelding 1 van 1
    • Cross it over the top of the knot to the right, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 9.
  8. How to Tie a Tie: Half-Windsor: stap 8, afbeelding 1 van 1
    • Pull the active end up through the loop around your neck, so that it is pointing straight up.
  9. How to Tie a Tie: Half-Windsor: stap 9, afbeelding 1 van 2 How to Tie a Tie: Half-Windsor: stap 9, afbeelding 2 van 2
    • Pull the active end down through the wrap you created in step 7 (see second picture).
  10. How to Tie a Tie: Half-Windsor, Finishing: stap 10, afbeelding 1 van 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  11. How to Tie a Tie: Half-Windsor: stap 11, afbeelding 1 van 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  12. How to Tie a Tie: Half-Windsor: stap 12, afbeelding 1 van 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Conclusie
Congratulations! You've successful tied the Half-Windsor knot!
4 andere personen hebben deze handleiding voltooid.
Electric Warthogs
776 Reputatie
3 handleidingen geschreven
The Electric Warthogs Lid van The Electric Warthogs
Community
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 955
