Ga door naar hoofdinhoud
How to Take in a Dress by Hand
Wat je nodig hebt
  1. How to Take in a Dress by Hand, How to Take in a Dress by Hand: stap 1, afbeelding 1 van 1
    • Lay the dress flat on a table.
  2. How to Take in a Dress by Hand: stap 2, afbeelding 1 van 2 How to Take in a Dress by Hand: stap 2, afbeelding 2 van 2
    • Measure the bust and waist of the dress with the measuring tape and write the measurements down.
    • Measure your own bust and waist. Subtract the your measurements from the dress measurements.
    • Divide these numbers by two.
    • This is the amount of fabric that will be removed from each side.
  3. How to Take in a Dress by Hand: stap 3, afbeelding 1 van 1
    • Turn the dress inside out.
    • Use the marker to mark the amount of bust and waist fabric that you are taking in for both sides.
  4. How to Take in a Dress by Hand: stap 4, afbeelding 1 van 1
    • Connect the marks with sewing pins (or safety pins) to make a clear path to sew along.
  5. How to Take in a Dress by Hand: stap 5, afbeelding 1 van 3 How to Take in a Dress by Hand: stap 5, afbeelding 2 van 3 How to Take in a Dress by Hand: stap 5, afbeelding 3 van 3
    • Thread the needle and leave plenty of excess thread for tying knots.
    • Start at the bottom of the new hem and weave the needle in and out of the dress until you reach the other side.
    • Tie a few knots at the end and cut the excess thread.
    • Now the new hem has been made.
  6. How to Take in a Dress by Hand: stap 6, afbeelding 1 van 3 How to Take in a Dress by Hand: stap 6, afbeelding 2 van 3 How to Take in a Dress by Hand: stap 6, afbeelding 3 van 3
    • Cut off the excess fabric with the fabric scissors. Stay about a centimeter away from the sewed line to make sure you do not cut the thread.
  7. How to Take in a Dress by Hand: stap 7, afbeelding 1 van 2 How to Take in a Dress by Hand: stap 7, afbeelding 2 van 2
    • Repeat all of the previous steps on the other side of the dress.
    • Turn your dress inside right, and that completes this guide.
Eindstreep
Olivia Collins
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 259
Altijd: 8,919
