Ga door naar hoofdinhoud
How to Tailor Your Pants
Wat je nodig hebt
  1. How to Tailor Your Pants, How to Tailor Your Pants: stap 1, afbeelding 1 van 1
    • To make the process of tailoring your pants easier, use a second pair of pants that already has the desired length as an outline.
    • Place the pants with the length you want on top of the pants that you will be tailoring.
  2. How to Tailor Your Pants: stap 2, afbeelding 1 van 1
    • Measure the length you want to cut off with your fingers.
    • The amount of fingers you use may vary depending on the length you want to cut off.
  3. How to Tailor Your Pants: stap 3, afbeelding 1 van 1
    • Pin your pants at the length you want to cut off.
    • An alternative option to pinning your pants is marking the length with a pencil.
  4. How to Tailor Your Pants: stap 4, afbeelding 1 van 1
    • Cut along the pins.
    • Cut along the pencil mark if you chose this option instead.
  5. How to Tailor Your Pants: stap 5, afbeelding 1 van 1
    • Fold the pants so that the seam is on the inside. Next, sew along the folded edge with a sewing machine.
    • Pin the pants to keep the fold in place and to make sewing easier.
  6. How to Tailor Your Pants: stap 6, afbeelding 1 van 1
    • Check to make sure your pants are now your desired length.
  7. How to Tailor Your Pants: stap 7, afbeelding 1 van 1
    • If you have achieved your desired length then you are finished!
Conclusie
You finally finished sewing your jeans so now you can enjoy wearing them :)
Exlexis Archouletta
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 704
