Inleiding
Use this guide to change the door swing on your Whirlpool Duet WED87HED dryer.
This guide is useful if your dryer has to be moved to a location where the door swing is inconvenient.
Removing the inner door face can be a little tricky. Take your time and make sure you remove only the screws with Phillips heads.
Wat je nodig hebt
Use a T25 Torx driver to remove the four 15.4 mm‑long screws holding the door hinge to the front panel.
Use a T25 Torx driver to remove the six 15.4 mm‑long screws securing the strike.
Lay the door face down on a towel or blanket before continuing to prevent any damage to the finish.
Use a Phillips #2 driver to remove the ten 17.6 mm‑long screws securing the inner door face.
Use a T25 Torx driver to remove the five 15.4 mm‑long screws securing the hinge.
Lay the door face down before continuing.
Use a T25 Torx driver to remove the three 15.4 mm‑long screws securing the catch plate and cover.
Remove the catch cover. The catch plate will fall off and rest inside the door frame.
Place the hinge into the position where you just removed the catch plate and catch cover.
Use a T25 Torx driver to replace the five 15.4 mm‑long screws securing the hinge.
With the inner door face lying flat on top of the door frame, lift the edge of the face where the hinge used to be.
Position the catch plate so that the boss on the catch plate will go through the rounded rectangular hole.
Replace the catch plate.
Take the catch plate cover with the three screws already in position and place it down over the catch location.
Use a T25 Torx driver to replace the three 15.4 mm‑long screws securing the catch plate and cover.
Slide the strike into the slot on the chassis across from its original location.
Position the door so that the hinge plate engages the slots in the chassis.
Use a T25 Torx driver to replace the four 15.4 mm‑long screws holding the door hinge to the front panel.
You're done and ready to start swinging!
Repair didn’t go as planned? Ask our Answers community for help.
