Ga door naar hoofdinhoud
How to Stitch a Hole on the Seam of a T-Shirt
Wat je nodig hebt
  1. How to Stitch a Hole on the Seam of a T-Shirt, How to Stitch a Hole on the Seam of a T-Shirt: stap 1, afbeelding 1 van 1
    • Turn the shirt inside out. This will ensure the new seam is sewn on the inside of the shirt.
  2. How to Stitch a Hole on the Seam of a T-Shirt: stap 2, afbeelding 1 van 3 How to Stitch a Hole on the Seam of a T-Shirt: stap 2, afbeelding 2 van 3 How to Stitch a Hole on the Seam of a T-Shirt: stap 2, afbeelding 3 van 3
    • Cut a long piece of thread and insert it into the loop of the needle .
    • Tie the loose ends of the thread into a small knot.
  3. How to Stitch a Hole on the Seam of a T-Shirt: stap 3, afbeelding 1 van 1
    • Take your thumb and first finger and pinch the sides of the hole together.
    • This will create less width for the needle to go through.
  4. How to Stitch a Hole on the Seam of a T-Shirt: stap 4, afbeelding 1 van 2 How to Stitch a Hole on the Seam of a T-Shirt: stap 4, afbeelding 2 van 2
    • Insert the needle on the edge of the hole.
    • Place the needle right below the tear of the fabric.
    • Make sure the knot of thread does not follow the needle while stitching and stays on the outside of the fabric.
  5. How to Stitch a Hole on the Seam of a T-Shirt: stap 5, afbeelding 1 van 2 How to Stitch a Hole on the Seam of a T-Shirt: stap 5, afbeelding 2 van 2
    • To secure the knot of thread, place the needle within the outside loop of thread and pull the needle through.
    • This will establish a firm base for a stitch.
  6. How to Stitch a Hole on the Seam of a T-Shirt: stap 6, afbeelding 1 van 3 How to Stitch a Hole on the Seam of a T-Shirt: stap 6, afbeelding 2 van 3 How to Stitch a Hole on the Seam of a T-Shirt: stap 6, afbeelding 3 van 3
    • With a firm pinch, start stitching the tear together by inserting the needle through both sides of the fabric, coming back to the side the needle was inserted on, and pulling tightly.
    • Make sure the thread does not get tangled, and make your stitches as close to one another as possible.
    • Continue this step until you have reached the end of the tear.
  7. How to Stitch a Hole on the Seam of a T-Shirt: stap 7, afbeelding 1 van 3 How to Stitch a Hole on the Seam of a T-Shirt: stap 7, afbeelding 2 van 3 How to Stitch a Hole on the Seam of a T-Shirt: stap 7, afbeelding 3 van 3
    • Once completed, take the needle and thread back to the first stitch.
    • Insert the needle through the first stitch until the thread has made a small loop outside of the seam.
    • Insert the needle through the small loop and pull tightly.
    • Repeat this step to secure the stitching from unraveling and cut the thread as close to the new seam as possible.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Aylin Castillo
172 Reputatie
1 Handleiding geschreven
Texas Tech, Team S14-G1, Cowan Fall 2020 Lid van Texas Tech, Team S14-G1, Cowan Fall 2020
TTU-COWAN-F20S14G1
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 46
Altijd: 2,294
