Ga door naar hoofdinhoud
How to Stabilize the Stem of a Longwise ES06 E-Scooter
Wat je nodig hebt
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 1, afbeelding 1 van 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 1, afbeelding 2 van 2
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 2, afbeelding 1 van 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 2, afbeelding 2 van 2
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 3, afbeelding 1 van 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 3, afbeelding 2 van 2
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 4, afbeelding 1 van 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 4, afbeelding 2 van 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 4, afbeelding 3 van 3
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 5, afbeelding 1 van 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 5, afbeelding 2 van 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 5, afbeelding 3 van 3
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 6, afbeelding 1 van 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: stap 6, afbeelding 2 van 2
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
Conclusie
Maithili Admane
133 Reputatie
1 Handleiding geschreven
York University, Team B-3, Allen Fall 2022 Lid van York University, Team B-3, Allen Fall 2022
YORK-ALLEN-F22SBG3
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 49
Altijd: 601
