Ga door naar hoofdinhoud
How to Shrink a Tennis Racket Grip
Wat je nodig hebt
  1. How to Shrink a Tennis Racket Grip, Remove Grip Tape: stap 1, afbeelding 1 van 1
    • Pull the tape until it comes off of the grip.
    • Use a sharp object to cut it off if needed.
  2. How to Shrink a Tennis Racket Grip, Remove the Overgrip: stap 2, afbeelding 1 van 2 How to Shrink a Tennis Racket Grip, Remove the Overgrip: stap 2, afbeelding 2 van 2
    • If your racket does not have an overgrip on it, then skip this step.
    • There is a good chance it is sticky.
  3. How to Shrink a Tennis Racket Grip, Put the Overgrip at the Bottom of the Handle: stap 3, afbeelding 1 van 1
    • Attach the smaller end of the new overgrip to the bottom of the handle.
    • Wrap the overgrip around the handle, parallel to the bottom of the grip.
  4. How to Shrink a Tennis Racket Grip, Wrap the Overgrip around the Handle: stap 4, afbeelding 1 van 1
    • Pull the grip tightly, leaving little to no open areas between the different parts of the overgrip.
    • Leave a little overlap between each row of your grip.
    • Most of your overgrip should cover the handle instead of a lower row of overgrip.
    • Make each row as close to the same size as possible.
  5. How to Shrink a Tennis Racket Grip, Put on the Tape: stap 5, afbeelding 1 van 2 How to Shrink a Tennis Racket Grip, Put on the Tape: stap 5, afbeelding 2 van 2
    • It should tie the end of the grip to the rest of the racket.
    • I did not cut the end of the overgrip with scissors. If you want the grip to fit better, cut the end of the overgrip off at a 45 degree angle.
Conclusie
If you decide that you want to go back to the racket grip's original size, then you need to remove the overgrip and put on a replacement grip.
Jim Watkins
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 72
