Ga door naar hoofdinhoud
How to Shorten the Length of a Shirt
Wat je nodig hebt
  1. How to Shorten the Length of a Shirt, How to Shorten the Length of a Shirt: stap 1, afbeelding 1 van 1
    • Pick the shirt that requires alterations, then select a different shirt has your desired fit and measurements.
    • Place the shirt that currently fits you on top of the shirt that is meant to be shortened.
    • Make sure both shirts line up perfectly with each other from the top, as you are going to use the shirt that fits you as the marker.
  2. How to Shorten the Length of a Shirt: stap 2, afbeelding 1 van 3 How to Shorten the Length of a Shirt: stap 2, afbeelding 2 van 3 How to Shorten the Length of a Shirt: stap 2, afbeelding 3 van 3
    • Trace a line along the oversized shirt to differentiate the extra length between the two shirts.
    • Follow the bottom edge of the above shirt, and draw a curve (or line) on the bottom shirt.
  3. How to Shorten the Length of a Shirt: stap 3, afbeelding 1 van 1
    • Measure the length from the curve drawn in the previous step to the bottom of the shirt to be altered.
    • The measurement should be done by holding the measuring tape vertical to the shirt.
  4. How to Shorten the Length of a Shirt: stap 4, afbeelding 1 van 3 How to Shorten the Length of a Shirt: stap 4, afbeelding 2 van 3 How to Shorten the Length of a Shirt: stap 4, afbeelding 3 van 3
    • Measure two inches up from the bottom of the shirt to be altered.
    • Use a pencil to make dots at the end of your measurement, and repeat this as you measure the entire length of the shirt.
    • Trace a line through the connection of the dots you drew in the last step.
  5. How to Shorten the Length of a Shirt: stap 5, afbeelding 1 van 3 How to Shorten the Length of a Shirt: stap 5, afbeelding 2 van 3 How to Shorten the Length of a Shirt: stap 5, afbeelding 3 van 3
    • Your shirt after tracing the two lines should look like this.
    • Cut the shirt to be altered along the newly drawn curve from the previous step.
  6. How to Shorten the Length of a Shirt: stap 6, afbeelding 1 van 2 How to Shorten the Length of a Shirt: stap 6, afbeelding 2 van 2
    • Prepare the sewing machine with thread that matches the shirt color.
    • If you don't have a string that matches the exact same color, then use one that has a similar shade.
  7. How to Shorten the Length of a Shirt: stap 7, afbeelding 1 van 3 How to Shorten the Length of a Shirt: stap 7, afbeelding 2 van 3 How to Shorten the Length of a Shirt: stap 7, afbeelding 3 van 3
    • Make a straight crease at the bottom of the shirt; the crease should be half an inch to one inch in length from the bottom.
  8. How to Shorten the Length of a Shirt: stap 8, afbeelding 1 van 2 How to Shorten the Length of a Shirt: stap 8, afbeelding 2 van 2
    • Identify the side of the shirt which faces the exterior; fold the shirt inside-out and flip the crease inwards when stitching the border.
    • The extra fabric at the end of the shirt should not be visible from the outside.
  9. How to Shorten the Length of a Shirt: stap 9, afbeelding 1 van 2 How to Shorten the Length of a Shirt: stap 9, afbeelding 2 van 2
    • Stitch on the regular setting of your sewing machine.
    • Set your range between 4 mm or up to 6 mm for your stitching.
    • On that stitching pattern, select the straight stitch on the sewing machine dial, or any alternative controls available (stitch selector should be 6 or 7).
    • The stitch tension should be 4.
  10. How to Shorten the Length of a Shirt: stap 10, afbeelding 1 van 2 How to Shorten the Length of a Shirt: stap 10, afbeelding 2 van 2
    • Before you start sewing, make sure to cut any loose or long threads (extra thread) that may interfere with your sewing.
    • This is important to ensure that the final product turns out nice.
  11. How to Shorten the Length of a Shirt: stap 11, afbeelding 1 van 3 How to Shorten the Length of a Shirt: stap 11, afbeelding 2 van 3 How to Shorten the Length of a Shirt: stap 11, afbeelding 3 van 3
    • Start to stitch on the folded line.
  12. How to Shorten the Length of a Shirt: stap 12, afbeelding 1 van 3 How to Shorten the Length of a Shirt: stap 12, afbeelding 2 van 3 How to Shorten the Length of a Shirt: stap 12, afbeelding 3 van 3
    • After finishing stitching the folded line, cut the extra thread.
  13. How to Shorten the Length of a Shirt: stap 13, afbeelding 1 van 2 How to Shorten the Length of a Shirt: stap 13, afbeelding 2 van 2
    • Iron the shirt and you have finished the fixing process.
    • Ironing the shirt is optional.
  14. How to Shorten the Length of a Shirt: stap 14, afbeelding 1 van 3 How to Shorten the Length of a Shirt: stap 14, afbeelding 2 van 3 How to Shorten the Length of a Shirt: stap 14, afbeelding 3 van 3
    • Examine the result.
    • Wear it and look great.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Vishal Mohan
247 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 225
Altijd: 7,856
