Ga door naar hoofdinhoud
How to Shorten a Belt
Wat je nodig hebt
  1. How to Shorten a Belt, How to Shorten a Belt: stap 1, afbeelding 1 van 1
    • Put your belt on.
    • Using a ruler or measuring tape, measure how much of the belt you want to remove. Make this mark on the buckle end of the belt.
    • Place a mark where you will cut the belt to shorten it.
  2. How to Shorten a Belt: stap 2, afbeelding 1 van 2 How to Shorten a Belt: stap 2, afbeelding 2 van 2
    • Measure how much of the belt is folded over the belt. Add that length to the cut mark to leave enough material to fold over the buckle.
    • Using a screwdriver, remove all screws from the buckle end of the belt.
  3. How to Shorten a Belt: stap 3, afbeelding 1 van 1
    • Using scissors, cut on the exact spot of your new mark.
    • You can round the edges of the cut to make the belt tip look neat.
    • You can add shoe or leather polish to the cut mark to ensure it is the same color as the belt.
  4. How to Shorten a Belt, Reassembling the Belt: stap 4, afbeelding 1 van 3 How to Shorten a Belt, Reassembling the Belt: stap 4, afbeelding 2 van 3 How to Shorten a Belt, Reassembling the Belt: stap 4, afbeelding 3 van 3
    • Reinsert the screws and screw them back in place using a screwdriver.
  5. How to Shorten a Belt, Add New Buckle Holes to the Belt: stap 5, afbeelding 1 van 2 How to Shorten a Belt, Add New Buckle Holes to the Belt: stap 5, afbeelding 2 van 2
    • Place your belt on a workspace that can be nailed into.
    • Place a nail on the new spot where you'd like to add a hole.
    • Hammer the nail until it goes all the way through the belt.
    • Caution: Be careful when using a hammer.
  6. How to Shorten a Belt: stap 6, afbeelding 1 van 2 How to Shorten a Belt: stap 6, afbeelding 2 van 2
    • Try on the belt and see if it fits comfortably.
    • If not, follow this guide again to add more holes.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Uvaldo Chan
154 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 53
Altijd: 1,922
