Ga door naar hoofdinhoud
How to Sew a Hole and reattach zippers to a purse
Wat je nodig hebt
  1. How to Sew a Hole and reattach zippers to a purse, Hole and Zippers: stap 1, afbeelding 1 van 1
    • Locate the hole.
    • It’s important to analyze the area and make sure you have enough thread to cover the area; more is always better.
  2. How to Sew a Hole and reattach zippers to a purse: stap 2, afbeelding 1 van 1
    • Get a needle and thread ready to sew and make a knot at the end of the thread.
  3. How to Sew a Hole and reattach zippers to a purse: stap 3, afbeelding 1 van 2 How to Sew a Hole and reattach zippers to a purse: stap 3, afbeelding 2 van 2
    • Sew the hole together.
    • Notice that the fabric looks smooth and straight, this is from folding the frayed parts of the fabric inward to make the sewing process easier.
    • Make sure to end your sewing session with a secured knot, and cut off excess thread.
  4. How to Sew a Hole and reattach zippers to a purse: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to grab one side of the opened coil.
  5. How to Sew a Hole and reattach zippers to a purse: stap 5, afbeelding 1 van 1
    • Locate the detached zipper slider and turn it backwards.
    • This is done while still holding one side of the opened coil.
  6. How to Sew a Hole and reattach zippers to a purse: stap 6, afbeelding 1 van 1
    • Place one side of the coil inside the zipper slider just a little using tweezers.
  7. How to Sew a Hole and reattach zippers to a purse: stap 7, afbeelding 1 van 2 How to Sew a Hole and reattach zippers to a purse: stap 7, afbeelding 2 van 2
    • Grab the other side of the opened coils and place that side inside the zipper slider.
    • Make sure that each of the coils are placed evenly inside the slider.
  8. How to Sew a Hole and reattach zippers to a purse: stap 8, afbeelding 1 van 2 How to Sew a Hole and reattach zippers to a purse: stap 8, afbeelding 2 van 2
    • Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
  9. How to Sew a Hole and reattach zippers to a purse: stap 9, afbeelding 1 van 3 How to Sew a Hole and reattach zippers to a purse: stap 9, afbeelding 2 van 3 How to Sew a Hole and reattach zippers to a purse: stap 9, afbeelding 3 van 3
    • Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
Conclusie
ReNieka Perry
223 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 85
Altijd: 1,822
