Ga door naar hoofdinhoud
How to Sew Torn Lace
Wat je nodig hebt
  1. How to Sew Torn Lace, How to Sew Torn Lace: stap 1, afbeelding 1 van 3 How to Sew Torn Lace, How to Sew Torn Lace: stap 1, afbeelding 2 van 3 How to Sew Torn Lace, How to Sew Torn Lace: stap 1, afbeelding 3 van 3
    • Cut a piece of thread around two feet in length.
    • Push the thread through the hole of the sewing needle.
    • Use a thread of matching color to the lace. This guide shows a thread that contrasts with the color of the lace for easier visibility.
    • Pull the thread until the ends meet.
    Vraag FixBot
    Voeg opmerking toe
  2. How to Sew Torn Lace: stap 2, afbeelding 1 van 3 How to Sew Torn Lace: stap 2, afbeelding 2 van 3 How to Sew Torn Lace: stap 2, afbeelding 3 van 3
    • Tie two overlapping knots at the end of the thread.
    Vraag FixBot
    Voeg opmerking toe
  3. How to Sew Torn Lace: stap 3, afbeelding 1 van 1
    • Place your lace on a flat and smooth surface.
    Vraag FixBot
    Voeg opmerking toe
  4. How to Sew Torn Lace: stap 4, afbeelding 1 van 1
    • Stick a pin near the hole, holding the lace in place.
    • Be careful with your fingers when inserting the pin.
    Vraag FixBot
    Voeg opmerking toe
  5. How to Sew Torn Lace: stap 5, afbeelding 1 van 3 How to Sew Torn Lace: stap 5, afbeelding 2 van 3 How to Sew Torn Lace: stap 5, afbeelding 3 van 3
    • Stitch the two sides of the hole together until you reach the end.
    • Keep stitches close together to avoid gaps in your stitch.
    • Be careful of the needle tip when sewing.
    Vraag FixBot
    Voeg opmerking toe
  6. How to Sew Torn Lace: stap 6, afbeelding 1 van 1
    • Stick the needle through to the back, or inside, of the lace.
    • Be careful of where you hands are placed when sticking the needle through.
    Vraag FixBot
    Voeg opmerking toe
  7. How to Sew Torn Lace: stap 7, afbeelding 1 van 3 How to Sew Torn Lace: stap 7, afbeelding 2 van 3 How to Sew Torn Lace: stap 7, afbeelding 3 van 3
    • Tie two overlapping knots to finish the stitch.
    • Keep the knot as close to the lace as possible.
    Vraag FixBot
    Voeg opmerking toe
  8. How to Sew Torn Lace: stap 8, afbeelding 1 van 3 How to Sew Torn Lace: stap 8, afbeelding 2 van 3 How to Sew Torn Lace: stap 8, afbeelding 3 van 3
    • Cut off any excess thread at the end of your stitch.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
Joanne Lai
157 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-2, Vidal-Chiesa Fall 2024 Lid van UC Davis, Team 3-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G2
3 Leden
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 57
Afgelopen 30 dagen: 305
Altijd: 1,370
