Ga door naar hoofdinhoud
How to Safely Remove Stickers from a Hydro Flask
Wat je nodig hebt
  1. How to Safely Remove Stickers from a Hydro Flask, How to Safely Remove Stickers from a Hydro Flask: stap 1, afbeelding 1 van 1
    • Soak the water bottle in warm water for 10 minutes.
  2. How to Safely Remove Stickers from a Hydro Flask: stap 2, afbeelding 1 van 2 How to Safely Remove Stickers from a Hydro Flask: stap 2, afbeelding 2 van 2
    • Dry the water bottle with a towel.
  3. How to Safely Remove Stickers from a Hydro Flask: stap 3, afbeelding 1 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 3, afbeelding 2 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 3, afbeelding 3 van 3
    • Turn the hair dryer on high heat.
    • Apply heat to each sticker for 30 seconds.
    • Slowly peel the sticker off while applying heat.
    • Caution: Be careful not to burn your fingers when peeling off the sticker.
  4. How to Safely Remove Stickers from a Hydro Flask: stap 4, afbeelding 1 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 4, afbeelding 2 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 4, afbeelding 3 van 3
    • Lather the water bottle in warm soapy water.
    • Scrub away at the residue with a sponge.
    • Dry down the water bottle with a towel.
  5. How to Safely Remove Stickers from a Hydro Flask: stap 5, afbeelding 1 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 5, afbeelding 2 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 5, afbeelding 3 van 3
    • Pour the isopropyl alcohol onto a cotton pad so that it is fully soaked.
    • Using pressure, rub the residue off of the water bottle with the cotton pad.
  6. How to Safely Remove Stickers from a Hydro Flask: stap 6, afbeelding 1 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 6, afbeelding 2 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 6, afbeelding 3 van 3
    • Scrape off the residue with a card. Scrape up to down.
    • Scrape from right to left.
  7. How to Safely Remove Stickers from a Hydro Flask: stap 7, afbeelding 1 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 7, afbeelding 2 van 3 How to Safely Remove Stickers from a Hydro Flask: stap 7, afbeelding 3 van 3
    • Coat a cotton swab in the isopropyl alcohol.
    • With pressure, rub off the residue with the cotton swab.
    • For any difficult residue follow this step.
  8. How to Safely Remove Stickers from a Hydro Flask: stap 8, afbeelding 1 van 2 How to Safely Remove Stickers from a Hydro Flask: stap 8, afbeelding 2 van 2
    • Enjoy your new water bottle!
Eindstreep
Karley Makar
157 Reputatie
1 Handleiding geschreven
UC Davis, Team 4-5, Vidal-Chiesa Fall 2024 Lid van UC Davis, Team 4-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G5
2 Leden
1 handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 35
Altijd: 316
