Ga door naar hoofdinhoud
How to Rewire a Lamp
Wat je nodig hebt
  1. How to Rewire a Lamp, Cord: stap 1, afbeelding 1 van 3 How to Rewire a Lamp, Cord: stap 1, afbeelding 2 van 3 How to Rewire a Lamp, Cord: stap 1, afbeelding 3 van 3
    • Before starting the process, remove the lamp shade and bulb by hand.
    • Make sure the lamp is unplugged to avoid the risk of electrocution.
  2. How to Rewire a Lamp: stap 2, afbeelding 1 van 3 How to Rewire a Lamp: stap 2, afbeelding 2 van 3 How to Rewire a Lamp: stap 2, afbeelding 3 van 3
    • Loosen the setscrew with the screwdriver so you can unscrew the socket base.
    • Unscrew the socket base from the threaded tube with your hand.
  3. How to Rewire a Lamp: stap 3, afbeelding 1 van 3 How to Rewire a Lamp: stap 3, afbeelding 2 van 3 How to Rewire a Lamp: stap 3, afbeelding 3 van 3
    • With your hand, pry the socket shell out of its base.
    • Remove the socket with your hand and then cut the wires with the wire cutters.
    • The neutral wire connects to the wide plug blade and is distinguished from the hot wire by ribs, color, printing, or indentations in the plastic insulation.
  4. How to Rewire a Lamp: stap 4, afbeelding 1 van 2 How to Rewire a Lamp: stap 4, afbeelding 2 van 2
    • Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
    • If you pull off any wire strands while stripping, cut back the cord with the Diagonal cutter.
  5. How to Rewire a Lamp: stap 5, afbeelding 1 van 3 How to Rewire a Lamp: stap 5, afbeelding 2 van 3 How to Rewire a Lamp: stap 5, afbeelding 3 van 3
    • By hand, tie an underwriters knot in the cord.
    • Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
    • An underwriter's knot prevents the wires from pulling out of the screw terminals when cord is tugged. ( The entire process of tying an underwriter knot can be done by hand . Form a loop using the first wire. Then, form a loop around the first wire and pass the tail through its loop. The strain on the cable is now taken by the knot.)
  6. How to Rewire a Lamp: stap 6, afbeelding 1 van 3 How to Rewire a Lamp: stap 6, afbeelding 2 van 3 How to Rewire a Lamp: stap 6, afbeelding 3 van 3
    • By hand, pull the excess cord down through the lamp.
    • Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
Eindstreep
Molly
119 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 37
Altijd: 1,283
