Ga door naar hoofdinhoud
How to Restuff a Plushie
Wat je nodig hebt
  1. How to Restuff a Plushie, How to Restuff a Plushie: stap 1, afbeelding 1 van 1
    • Choose an area to open the seam of the plushie.
    • Choose an area where the new stitches will not be as noticeable, such as on an underside or another area that will not be seen.
  2. How to Restuff a Plushie: stap 2, afbeelding 1 van 3 How to Restuff a Plushie: stap 2, afbeelding 2 van 3 How to Restuff a Plushie: stap 2, afbeelding 3 van 3
    • Partially unpick the seam using a seam ripper or pair of scissors (about 2 inches).
    • Be sure to place hands carefully and away from the path of the seam ripper to ensure no injures.
  3. How to Restuff a Plushie: stap 3, afbeelding 1 van 2 How to Restuff a Plushie: stap 3, afbeelding 2 van 2
    • Remove all of the old stuffing from the plushie.
  4. How to Restuff a Plushie: stap 4, afbeelding 1 van 3 How to Restuff a Plushie: stap 4, afbeelding 2 van 3 How to Restuff a Plushie: stap 4, afbeelding 3 van 3
    • Fill a sink or bowl with warm water and light detergent.
    • Gently hand wash your plushie.
    • Drain and replace the container with clean and warm water.
    • Rinse off the plushie and wring it until it is no longer dripping.
  5. How to Restuff a Plushie: stap 5, afbeelding 1 van 1
    • Hang dry the plushie using a hanger or clothesline until completely dry.
    • Machine drying can damage or burn the fabric of the plushie
  6. How to Restuff a Plushie: stap 6, afbeelding 1 van 3 How to Restuff a Plushie: stap 6, afbeelding 2 van 3 How to Restuff a Plushie: stap 6, afbeelding 3 van 3
    • Once dry, fill the plushie with new stuffing.
    • Stuffing the plushie little by little ensures the whole plushie gets re-stuffed properly and evenly.
  7. How to Restuff a Plushie: stap 7, afbeelding 1 van 3 How to Restuff a Plushie: stap 7, afbeelding 2 van 3 How to Restuff a Plushie: stap 7, afbeelding 3 van 3
    • Pull the thread through the eye of the needle.
    • Create a knot at the end of the thread.
  8. How to Restuff a Plushie: stap 8, afbeelding 1 van 1
    • Fold the fabric of the opening (about 1 cm) inward to create two folds.
  9. How to Restuff a Plushie: stap 9, afbeelding 1 van 3 How to Restuff a Plushie: stap 9, afbeelding 2 van 3 How to Restuff a Plushie: stap 9, afbeelding 3 van 3
    • Insert the needle through the inside edge of the folded fabric
    • Make a stitch in the inside fold and pull the thread through.
    • Insert the needle on the other fold and make a stitch
    • Pull the thread through and alternate stitches until you reach the other side of the opening.
    • Take your time and carefully place your hands in a safe position when inserting the needle into the fabric. This can prevent injures.
  10. How to Restuff a Plushie: stap 10, afbeelding 1 van 3 How to Restuff a Plushie: stap 10, afbeelding 2 van 3 How to Restuff a Plushie: stap 10, afbeelding 3 van 3
    • Thread the needle through the inside stitches to loop and knot the end of the thread.
    • Repeat several times to secure the stitch.
  11. How to Restuff a Plushie: stap 11, afbeelding 1 van 2 How to Restuff a Plushie: stap 11, afbeelding 2 van 2
    • Cut the excess thread with scissors.
  12. How to Restuff a Plushie: stap 12, afbeelding 1 van 1
    • Enjoy your renewed plushie!
Conclusie
Your plushie is now looking almost brand new!
Één andere persoon heeft deze handleiding voltooid.
Sally Lee
220 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-4, Andersen Winter 2024 Lid van UC Davis, Team 2-4, Andersen Winter 2024
UCD-ANDERSEN-W24S2G4
3 Leden
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 207
Altijd: 1,522
