Ga door naar hoofdinhoud
How to Restore a Used Canvas
Wat je nodig hebt
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: stap 1, afbeelding 1 van 2 How to Restore a Used Canvas, How to Restore a Used Canvas: stap 1, afbeelding 2 van 2
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: stap 2, afbeelding 1 van 2 How to Restore a Used Canvas: stap 2, afbeelding 2 van 2
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: stap 3, afbeelding 1 van 1
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: stap 4, afbeelding 1 van 3 How to Restore a Used Canvas: stap 4, afbeelding 2 van 3 How to Restore a Used Canvas: stap 4, afbeelding 3 van 3
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: stap 5, afbeelding 1 van 1
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: stap 6, afbeelding 1 van 1
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: stap 7, afbeelding 1 van 3 How to Restore a Used Canvas: stap 7, afbeelding 2 van 3 How to Restore a Used Canvas: stap 7, afbeelding 3 van 3
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: stap 8, afbeelding 1 van 3 How to Restore a Used Canvas: stap 8, afbeelding 2 van 3 How to Restore a Used Canvas: stap 8, afbeelding 3 van 3
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
Eindstreep
Sandra Henriquez
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 38
Altijd: 599
