Ga door naar hoofdinhoud
How to Restore a Dented Hydro Flask
Wat je nodig hebt
  1. How to Restore a Dented Hydro Flask, How to Restore a Dented Hydro Flask: stap 1, afbeelding 1 van 1
    • Empty your Hydro Flask water bottle and clean the exterior.
    • You may want to remove stickers around the dent to see the damage more clearly.
  2. How to Restore a Dented Hydro Flask: stap 2, afbeelding 1 van 1
    • Boil enough water to pour over the dent.
  3. How to Restore a Dented Hydro Flask: stap 3, afbeelding 1 van 2 How to Restore a Dented Hydro Flask: stap 3, afbeelding 2 van 2
    • Prepare an ice bath by filling a bin with water and ice in a small tub.
  4. How to Restore a Dented Hydro Flask: stap 4, afbeelding 1 van 3 How to Restore a Dented Hydro Flask: stap 4, afbeelding 2 van 3 How to Restore a Dented Hydro Flask: stap 4, afbeelding 3 van 3
    • Place your Hydro Flask in an empty sink.
    • Pour the boiling water directly onto the dented area for about 10 seconds.
    • Boiling water can cause burns to the skin, protective gloves are suggested.
  5. How to Restore a Dented Hydro Flask: stap 5, afbeelding 1 van 1
    • Immediately submerge the dented area into the prepared ice bath for about 10 seconds.
    • Handle the bottle with caution as it may still be hot from the previous step. Use protective gloves as suggested.
  6. How to Restore a Dented Hydro Flask: stap 6, afbeelding 1 van 1
    • Use a wooden spoon to reach inside the Hydro Flask and push out the dent.
    • Any solid object long enough to reach the dent will also work.
Conclusie
Madelyn
133 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-7, Morris Winter 2023 Lid van UC Davis, Team 2-7, Morris Winter 2023
UCD-MORRIS-W23S2G7
2 Leden
6 handleidingen geschreven
Één opmerking
Ma con una borraccia termica(quindi a doppia parete) come si può fare?
Francesca Basile - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 71
Afgelopen 7 dagen: 470
Afgelopen 30 dagen: 1,803
Altijd: 17,128
