Inleiding
If your golf shoes are having turf-gripping problems that have to do with worn or dirty golf shoe spikes, use this guide to restore your spikes to proper working condition.
It is important for all golfers to have clean golf shoe spikes. Having poorly cleansed golf shoe spikes can hinder the performance of the player and stop a them from competing to the best of their ability. If your spikes are clean, your traction on the ground won’t be a concern and the only thing you will need to focus on is swinging the golf club.
Before using this guide, make sure that the reason that your shoes are not properly gripping is due to soiled spikes. Some shoes lose grip because dirt/mud is covering the shoe. If this is the case, you will have to clean more than just the spikes.
This guide includes work with some potentially sharp components. When handling these tools, make sure to do so with caution and with hand protection, like a glove.
Wat je nodig hebt
Take one of the golf shoes and place it so that the bottom of the shoe is facing upwards.
Use the Golf Utility Brush to remove any sort of dirt and debris from each individual golf shoe spike.
Lay each of the spikes out on a towel.
Use the Golf Utility Brush to clean the loosened dirt and debris from the side of the golf spike where the screw-in portion is.
Flip the golf spike over to the gripped side and scrub away any dirt remnants so that the golf spike is as clean as possible.
Once all of the spikes are reinserted, repeat the whole process with the second shoe.
Één opmerking
Is there anyway to fix the insert the spike fits into? I keep losing spikes daily
