Ga door naar hoofdinhoud
How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable
Wat je nodig hebt
  1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 1, afbeelding 1 van 2 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 1, afbeelding 2 van 2
    • Carefully remove the plastic cover and set aside.
  2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 2, afbeelding 1 van 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 2, afbeelding 2 van 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 2, afbeelding 3 van 3
    • Remove the pad if there is one.
    • Spin the turntable until the belt and drive motor can be seen through a hole.
    • Gently pull the belt off of the motor, and make sure that the belt doesn’t bend or flip over.
    • Take off the turntable platter and set aside.
  3. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 3, afbeelding 1 van 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 3, afbeelding 2 van 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 3, afbeelding 3 van 3
    • Remove the single screw from the middle white gear with a Phillips #00 screwdriver.
    • Have a cup or bin so you don’t lose the screw!
    • Gently pull the gear out, revealing the automatic mechanism.
  4. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 4, afbeelding 1 van 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 4, afbeelding 2 van 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 4, afbeelding 3 van 3
    • Push the metal part away from the center. It should click into place.
    • Push the small metal part back to the center, towards the gear axle.
    • Push the metal part inward, close to the gear’s mounting point.
  5. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: stap 5, afbeelding 1 van 1
    • Replace the gear, making sure that the the metal latch on the gear is pushed back.
    • The central shaft should spin freely without hooking the gear.
    • Don't forget to put the band back on the drive motor when reassembling.
Conclusie
Devin Hoopes
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 79
Altijd: 2,315
