Ga door naar hoofdinhoud
How to Reset a Crooked Dresser Drawer
  1. How to Reset a Crooked Dresser Drawer, How to Reset a Crooked Dresser Drawer: stap 1, afbeelding 1 van 2 How to Reset a Crooked Dresser Drawer, How to Reset a Crooked Dresser Drawer: stap 1, afbeelding 2 van 2
    • Empty out the crooked drawer before removing it.
    • Grab hold of the handle and pull the crooked drawer out slowly until it cannot go any further. You can tell when it starts to rock forward.
    • When the drawer rocks forward, do not let go of the handle. Letting go will lead to the drawer falling out and may cause injury.
  2. How to Reset a Crooked Dresser Drawer: stap 2, afbeelding 1 van 2 How to Reset a Crooked Dresser Drawer: stap 2, afbeelding 2 van 2
    • Grab one side of the drawer with your free hand. Let go of the handle and grab the other side of the drawer.
    • Pull it straight out towards yourself, lifting slightly. The crooked drawer will come out of the dresser completely.
  3. How to Reset a Crooked Dresser Drawer: stap 3, afbeelding 1 van 2 How to Reset a Crooked Dresser Drawer: stap 3, afbeelding 2 van 2
    • Set the drawer down. Check the two metal slides and rollers on both sides of the drawer for damages. Make sure they are not loose.
  4. How to Reset a Crooked Dresser Drawer: stap 4, afbeelding 1 van 2 How to Reset a Crooked Dresser Drawer: stap 4, afbeelding 2 van 2
    • Inside the dresser, check the two metal tracks and square locks on both sides for damages. Make sure they are parallel to the edges of the drawer and not loose.
  5. How to Reset a Crooked Dresser Drawer: stap 5, afbeelding 1 van 2 How to Reset a Crooked Dresser Drawer: stap 5, afbeelding 2 van 2
    • Hold the drawer on both sides and bring it up to the opening of the dresser where you removed it.
    • Align the rollers on the drawer with the square locks on the inside of the dresser. Set the rollers on top of the square locks on the inside of the dresser.
  6. How to Reset a Crooked Dresser Drawer: stap 6, afbeelding 1 van 1
    • Hold the drawer on both sides and slightly tilt the front of the drawer upward.
  7. How to Reset a Crooked Dresser Drawer: stap 7, afbeelding 1 van 2 How to Reset a Crooked Dresser Drawer: stap 7, afbeelding 2 van 2
    • Holding the sides still, slowly ease the drawer forward and then down so that the drawer is leveled. You will hear and feel a click.
    • Let go of the sides and grab the handle of the drawer.
    • Push the drawer closed and then pull it open again to make sure it slides back and forth with ease.
  8. How to Reset a Crooked Dresser Drawer: stap 8, afbeelding 1 van 1
    • Shut the drawer completely and step back to make sure that all drawers are now flush.
Conclusie
Huong
157 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G42, Cardinal Spring 2020 Lid van UW Tacoma, Team S1-G42, Cardinal Spring 2020
UWT-CARDINAL-S20S1G42
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 188
Altijd: 9,886
