Ga door naar hoofdinhoud
How to Reseal a 55 Gallon Fish Tank
Wat je nodig hebt
  1. How to Reseal a 55 Gallon Fish Tank, Silicone Seal: stap 1, afbeelding 1 van 3 How to Reseal a 55 Gallon Fish Tank, Silicone Seal: stap 1, afbeelding 2 van 3 How to Reseal a 55 Gallon Fish Tank, Silicone Seal: stap 1, afbeelding 3 van 3
    • Clean the tank.
    • Be sure to remove all foreign substances.
    • Inspect the seal for possibility of removal without tools.
    • Check the old seals for mold.
    • The new silicone must have a clean surface to bond to.
    • Mark where the leak is and make sure to pay close attention to that side when applying silicone.
  2. How to Reseal a 55 Gallon Fish Tank: stap 2, afbeelding 1 van 3 How to Reseal a 55 Gallon Fish Tank: stap 2, afbeelding 2 van 3 How to Reseal a 55 Gallon Fish Tank: stap 2, afbeelding 3 van 3
    • Get the razor blade underneath the seal, and scrape from the top to the bottom, with long and steady cuts to remove the sealant.
    • Do not insert the blade in-between the panels because that can separate the glass.
  3. How to Reseal a 55 Gallon Fish Tank: stap 3, afbeelding 1 van 3 How to Reseal a 55 Gallon Fish Tank: stap 3, afbeelding 2 van 3 How to Reseal a 55 Gallon Fish Tank: stap 3, afbeelding 3 van 3
    • Remove the remaining silicone with paper towels, acetone, and a vacuum.
    • Apply acetone until you do not feel any sticky residue (silicone).
    • If the silicone does not come off with the acetone, use razor blades to assist in any final removal.
    • The new silicone will not bond unless all of the old silicone is removed.
  4. How to Reseal a 55 Gallon Fish Tank: stap 4, afbeelding 1 van 3 How to Reseal a 55 Gallon Fish Tank: stap 4, afbeelding 2 van 3 How to Reseal a 55 Gallon Fish Tank: stap 4, afbeelding 3 van 3
    • Apply tape along the interior edges of the tank.
    • Leave a gap between the interior corners and the lines of tape.
    • The gap should be approximately 1/2 inch.
  5. How to Reseal a 55 Gallon Fish Tank: stap 5, afbeelding 1 van 3 How to Reseal a 55 Gallon Fish Tank: stap 5, afbeelding 2 van 3 How to Reseal a 55 Gallon Fish Tank: stap 5, afbeelding 3 van 3
    • Cut the tip of the silicone at the three-eighths mark.
    • Press the caulking gun to apply an even bead ¼” bead of silicone along the corners.
    • Apply it quickly because the silicone dries within minutes.
    • Consider where the original leak was and apply extra silicone as needed.
  6. How to Reseal a 55 Gallon Fish Tank: stap 6, afbeelding 1 van 2 How to Reseal a 55 Gallon Fish Tank: stap 6, afbeelding 2 van 2
    • Spread out the silicone bead across all the interior corners with your finger.
    • This process is sticky. We recommend wearing gloves.
  7. How to Reseal a 55 Gallon Fish Tank: stap 7, afbeelding 1 van 3 How to Reseal a 55 Gallon Fish Tank: stap 7, afbeelding 2 van 3 How to Reseal a 55 Gallon Fish Tank: stap 7, afbeelding 3 van 3
    • Leave your tank in a place free of dust and contaminants. Wait a minimum of 48 hours to dry.
    • Peel the tape back to slowly remove it.
    • Adding water or reintroducing your fish early can ruin the process and it might harm your fish.
Conclusie
Be patient with the drying process and only reintroduce water and fish when it's ready. Enjoy your repaired and leak-free aquarium!
Één andere persoon heeft deze handleiding voltooid.
Oriana
163 Reputatie
1 Handleiding geschreven
UC Davis, Team 4-2, Andersen Winter 2023 Lid van UC Davis, Team 4-2, Andersen Winter 2023
UCD-ANDERSEN-W23S4G2
4 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 41
Altijd: 634
