Ga door naar hoofdinhoud
How to Replace the Wheels on an Office Chair
Wat je nodig hebt
  1. How to Replace the Wheels on an Office Chair, Removing Casters: stap 1, afbeelding 1 van 1
    • Lay the chair down.
    • If the chair is too heavy to turn upside down, have someone help you do it.
  2. How to Replace the Wheels on an Office Chair: stap 2, afbeelding 1 van 1
    • Wipe the stem of the caster with a rag or paper towel to remove any dust or debris.
  3. How to Replace the Wheels on an Office Chair: stap 3, afbeelding 1 van 3 How to Replace the Wheels on an Office Chair: stap 3, afbeelding 2 van 3 How to Replace the Wheels on an Office Chair: stap 3, afbeelding 3 van 3
    • Use a flathead screwdriver in between the caster and the base of the chair to pry the wheel out of the socket.
    • Turn the screwdriver gently until the caster starts to move upwards away from the chair.
    • Try rotating the screwdriver at different angles if the caster won't come out.
  4. How to Replace the Wheels on an Office Chair: stap 4, afbeelding 1 van 3 How to Replace the Wheels on an Office Chair: stap 4, afbeelding 2 van 3 How to Replace the Wheels on an Office Chair: stap 4, afbeelding 3 van 3
    • Use a prying tool that is big enough to fit between the caster and over the stem.
    • Gently pull on the caster upwards and it should come off.
  5. How to Replace the Wheels on an Office Chair: stap 5, afbeelding 1 van 2 How to Replace the Wheels on an Office Chair: stap 5, afbeelding 2 van 2
    • Measure the wheel's height and length.
    • Once you've done that, purchase your new casters.
    • Large casters(about 3"), are more durable and versatile. Twin-wheel casters are usually used in office settings.
  6. How to Replace the Wheels on an Office Chair: stap 6, afbeelding 1 van 2 How to Replace the Wheels on an Office Chair: stap 6, afbeelding 2 van 2
    • Push the caster's stem into the bottom of chair leg.
    • Install the new casters.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Ismail Dhorre
160 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 57
Altijd: 6,315
