Ga door naar hoofdinhoud
How to Replace the Tip of a Hiking Pole
Wat je nodig hebt
  1. How to Replace the Tip of a Hiking Pole, Identify the repair area: stap 1, afbeelding 1 van 2 How to Replace the Tip of a Hiking Pole, Identify the repair area: stap 1, afbeelding 2 van 2
    • Prepare all the tools needed for the repair and locate the tip of the hiking pole that needs to be fixed.
  2. How to Replace the Tip of a Hiking Pole, Prepare the hiking pole: stap 2, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Prepare the hiking pole: stap 2, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Prepare the hiking pole: stap 2, afbeelding 3 van 3
    • In order to protect the pole from scratching, secure it with scotch tape.
  3. How to Replace the Tip of a Hiking Pole, Remove the tip: stap 3, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Remove the tip: stap 3, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Remove the tip: stap 3, afbeelding 3 van 3
    • Following the direction of the orange arrows, use an adjustable wrench to slide it fast along the hiking pole and push the tip outwards.
  4. How to Replace the Tip of a Hiking Pole, Insert the new tip: stap 4, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Insert the new tip: stap 4, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Insert the new tip: stap 4, afbeelding 3 van 3
    • Insert the replacement tip manually by pushing it inwards.
  5. How to Replace the Tip of a Hiking Pole, Set the new tip in place: stap 5, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Set the new tip in place: stap 5, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Set the new tip in place: stap 5, afbeelding 3 van 3
    • Use a hammer to secure the tip in its new position.
    • Note: only hit it once or twice with a hard tap.
  6. How to Replace the Tip of a Hiking Pole, Finished and ready!: stap 6, afbeelding 1 van 1
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • ...However if you need a reinforced fix, please continue on the next steps.
  7. How to Replace the Tip of a Hiking Pole, Collect the extra tools: stap 7, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Collect the extra tools: stap 7, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Collect the extra tools: stap 7, afbeelding 3 van 3
    • Collect the tools needed for the reinforced fix.
    • Mix the two-component glue and continue on the next step.
  8. How to Replace the Tip of a Hiking Pole, Prepare the glue: stap 8, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Prepare the glue: stap 8, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Prepare the glue: stap 8, afbeelding 3 van 3
    • Keep mixing the glue until you notice it starts to change texture.
    • The texture should be "thick" and the color should change from transparent to white.
  9. How to Replace the Tip of a Hiking Pole, Apply the glue: stap 9, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Apply the glue: stap 9, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Apply the glue: stap 9, afbeelding 3 van 3
    • Use a piece of cardboard to apply the mixed glue on the top of the tip of the hiking pole.
    • Spread the glue evenly over the surface of the tip.
  10. How to Replace the Tip of a Hiking Pole, Insert the tip: stap 10, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Insert the tip: stap 10, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Insert the tip: stap 10, afbeelding 3 van 3
    • Like in "Step 4", insert the replacement tip manually by pushing it inwards.
  11. How to Replace the Tip of a Hiking Pole, Secure the tip: stap 11, afbeelding 1 van 3 How to Replace the Tip of a Hiking Pole, Secure the tip: stap 11, afbeelding 2 van 3 How to Replace the Tip of a Hiking Pole, Secure the tip: stap 11, afbeelding 3 van 3
    • Like in "Step 5", use a hammer to secure the tip in its new position.
    • Clean the excess glue with a spare piece of cardboard.
  12. How to Replace the Tip of a Hiking Pole, Finished and ready!: stap 12, afbeelding 1 van 2 How to Replace the Tip of a Hiking Pole, Finished and ready!: stap 12, afbeelding 2 van 2
Conclusie
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10.230 Reputatie
66 handleidingen geschreven
INTERSPORT Lid van INTERSPORT
Community
25 Leden
169 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 679
