Ga door naar hoofdinhoud
How to Replace the Suction Cups for the Anti-Clamp
  1. How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: stap 1, afbeelding 1 van 2 How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: stap 1, afbeelding 2 van 2
    • The suction cups are secured to the clamp by friction-fit pins.
    • To remove the pins, you have to push them through their indents in the clamp's arms.
  2. How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: stap 2, afbeelding 1 van 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: stap 2, afbeelding 2 van 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • Rotate the suction cup towards the indentation in the clamp's arm to release the pin.
    • You may need to use significant force and another hand to support the Anti-Clamp.
    • Remove the suction cup and its pin.
    • During reassembly, angle the pin into the hole across from the indent before pushing it back into the arm.
  3. How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: stap 3, afbeelding 1 van 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: stap 3, afbeelding 2 van 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: stap 3, afbeelding 3 van 3
    • Pull the pin through the top of the suction cup and remove it.
Conclusie
For other general electronics skills guides, click here.
Alex Diaz-Kokaisl
212.518 Reputatie
1.037 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.584 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 41
Altijd: 1,174
