Ga door naar hoofdinhoud
How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta
Wat je nodig hebt
  1. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta, Side Mirror Glass: stap 1, afbeelding 1 van 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta, Side Mirror Glass: stap 1, afbeelding 2 van 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta, Side Mirror Glass: stap 1, afbeelding 3 van 3
    • Turn on the accessory power.
    • Twist the mirror adjustment knob to the side you are working on (L for left, R for right).
    • Push the knob so that the mirror will angle towards the car.
    • Turn off the accessory power.
  2. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 2, afbeelding 1 van 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 2, afbeelding 2 van 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 2, afbeelding 3 van 3
    • Pull the mirror from the exposed back.
    • There will be an audible pop when the mirror is fully detached.
    • Use extra strength to pull out the mirror if needed. Do not worry about breaking the mirror.
  3. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 3, afbeelding 1 van 2 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 3, afbeelding 2 van 2
    • Pull hard to release the wire from the metal prong, one at a time.
    • If the wire is stuck, wiggle it from side to side.
    • Hold the mirror firmly to avoid accidentally dropping it.
  4. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 4, afbeelding 1 van 2 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 4, afbeelding 2 van 2
    • Reattach the wires to the metal prongs located on the new mirror.
    • The purple wire goes to the prong furthest from the center of the mirror.
    • The red wire goes to the prong closest to the center of the mirror.
    • Make sure the wires are fully pushed in.
  5. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 5, afbeelding 1 van 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 5, afbeelding 2 van 3 How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 5, afbeelding 3 van 3
    • Line up the mirror with the housing and push in the central area.
    • The mirror will audibly pop once fully reinstalled.
  6. How to Replace the Side Mirror Glass on a 2011-2017 Volkswagen Jetta: stap 6, afbeelding 1 van 1
    • Turn the accessory power on.
    • Using the adjustment knob, move the mirror back to a normal viewing angle.
Conclusie
Follow these instructions for either side mirror. The only difference will be which mirror you adjust using the mirror adjustment knob in step 1.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 200
Altijd: 7,977
