Ga door naar hoofdinhoud
How to Replace the Net on a Basketball Hoop
Wat je nodig hebt
  1. How to Replace the Net on a Basketball Hoop, Net: stap 1, afbeelding 1 van 1
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. How to Replace the Net on a Basketball Hoop: stap 2, afbeelding 1 van 3 How to Replace the Net on a Basketball Hoop: stap 2, afbeelding 2 van 3 How to Replace the Net on a Basketball Hoop: stap 2, afbeelding 3 van 3
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. How to Replace the Net on a Basketball Hoop: stap 3, afbeelding 1 van 1
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. How to Replace the Net on a Basketball Hoop: stap 4, afbeelding 1 van 1
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. How to Replace the Net on a Basketball Hoop: stap 5, afbeelding 1 van 1
    • Step down from the ladder and play ball.
Conclusie
Now that you've replaced your net, you're ready play some basketball.
3 andere personen hebben deze handleiding voltooid.
Kevin A Walker
164 Reputatie
1 Handleiding geschreven
Cal Poly, Team 23-3, Green Winter 2015 Lid van Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 Leden
13 handleidingen geschreven
3Gids Commentaar
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - Antwoord
i don't have these things were I can like put the net in
leon reichert - Antwoord
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 246
Altijd: 119,871
