Inleiding
Is your front-turn signal light bulb in your 2011 Subaru Impreza Outback Sport going out? Use this guide to replace the dead bulb with a new one and have a working turn signal again.
Wat je nodig hebt
First, check to see if your front-turn signal is not working properly or not bright enough.
4 andere personen hebben deze handleiding voltooid.
3 opmerkingen
I'm glad I looked here. I was ready to go in from above and move the battery so I could get at the bulb socket. This method was easier--and had the advantage of working, which I can't say was true of the approach I had in mind. The drive was wet and I didn't have my flashlight, so I did it all by feel., seated on an upended plastic bucket. Heavy rubber gloves might help. I almost scored the back of my hand, but managed to avoid that. Excellent advice.
My wheel well & bumper was a bit harder to remove (a few more plastic rivets holding it on) but I was able to get it open enough to reach up - easy enough to remove by feel. Thanks for the guide!
This method worked and i did not have to remove the battery.
The hardest part was removing the little plastic rivets without breaking them. (I broke one.) You will need to remove four plastic rivets total. Three vertical and one on the bottom of the side quarter panel. For some reason two of the rivets have phillips head slots, but the other two have no slots and must be carefully pried.
Once you unscrew the bulb socket, you will need to pull the assembly downward as far as possible in order to get both hands on the bulb.
Good luck.
Stephen
