Ga door naar hoofdinhoud
How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra
Wat je nodig hebt
  1. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra, Dashboard Tweeter: stap 1, afbeelding 1 van 2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra, Dashboard Tweeter: stap 1, afbeelding 2 van 2
    • Take your flat head screwdriver and gently pry off the plastic grille covering your tweeter.
    • There are 4 clips holding the grille down, 1 in each corner. Be careful not to break them.
  2. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 2, afbeelding 1 van 2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 2, afbeelding 2 van 2
    • Take your offset screwdriver and unscrew the screws holding down the tweeter bracket.
    • Some models and years have 2 screws, others have 4. Remove them all.
  3. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 3, afbeelding 1 van 2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 3, afbeelding 2 van 2
    • Gently lift the tweeter bracket with the tweeter inside and locate the connector.
  4. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 4, afbeelding 1 van 1
    • Unbox your new tweeter and place it inside of the bracket that it comes with.
    • Refer to the manual included with the tweeter for this step. Bracket installation varies between models.
  5. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 5, afbeelding 1 van 3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 5, afbeelding 2 van 3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 5, afbeelding 3 van 3
    • Disconnect the old tweeter from the car.
    • Make sure to note that the positive wire has a red line on it. This is important.
  6. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 6, afbeelding 1 van 3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 6, afbeelding 2 van 3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 6, afbeelding 3 van 3
    • Take your new tweeter and plug it in to the same connections as the old one.
    • Make sure that you connect the positive lead to the lead you noted earlier (red line). Connecting them incorrectly could result in damage to your tweeter or stereo.
  7. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 7, afbeelding 1 van 2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 7, afbeelding 2 van 2
    • If your tweeter only has 2 screws, attach a zip tie through the other holes and over the tweeter to help secure it in place.
    • Cut off the excess tie.
  8. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 8, afbeelding 1 van 1
    • Take any excess cable and fold it neatly so that it will fit down the hole below the tweeter.
  9. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 9, afbeelding 1 van 1
    • Place the new tweeter and bracket assembly back into the dashboard.
    • Make sure the orientation is how you would like it, and that the holes of the bracket line up with the holes in the dashboard.
  10. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 10, afbeelding 1 van 1
    • Place the screws from the original tweeter back in their holes and tighten them with the offset screw driver.
    • Make sure you do not over tighten them! Over tightening can strip the plastic that holds them in place. Snug is good.
  11. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 11, afbeelding 1 van 2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: stap 11, afbeelding 2 van 2
    • Replace the grille that covers the tweeter.
    • Make sure you install it in the correct orientation. It should snap in easily. Installing incorrectly could damage the clips.
Conclusie
You have succesfully replaced your tweeter. Follow the same steps to do the other side and test your stereo to make sure they are installed properly.
4 andere personen hebben deze handleiding voltooid.
Justin McGowan
182 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-5, Green Fall 2015 Lid van Cal Poly, Team 15-5, Green Fall 2015
CPSU-GREEN-F15S15G5
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 80
Altijd: 21,649
