Ga door naar hoofdinhoud
How to Replace the Battery of your 2019 Ford Fiesta Key Fob
Wat je nodig hebt
  1. How to Replace the Battery of your 2019 Ford Fiesta Key Fob, Key Fob Battery: stap 1, afbeelding 1 van 3 How to Replace the Battery of your 2019 Ford Fiesta Key Fob, Key Fob Battery: stap 1, afbeelding 2 van 3 How to Replace the Battery of your 2019 Ford Fiesta Key Fob, Key Fob Battery: stap 1, afbeelding 3 van 3
    • Use a washer or opening tool in the gap on the right-hand side of the key fob to pry the top case off of the fob.
    • Work your way around the edge of the fob with the opening tool to release the clips of the case.
  2. How to Replace the Battery of your 2019 Ford Fiesta Key Fob: stap 2, afbeelding 1 van 2 How to Replace the Battery of your 2019 Ford Fiesta Key Fob: stap 2, afbeelding 2 van 2
    • After separating the key fob, you'll see the battery on the side of the fob with the key attached.
  3. How to Replace the Battery of your 2019 Ford Fiesta Key Fob: stap 3, afbeelding 1 van 2 How to Replace the Battery of your 2019 Ford Fiesta Key Fob: stap 3, afbeelding 2 van 2
    • Use an opening tool to pry the battery out of the key fob.
  4. How to Replace the Battery of your 2019 Ford Fiesta Key Fob: stap 4, afbeelding 1 van 1
    • Next, insert the new CR2032 3V battery into the key fob where the old one was located.
  5. How to Replace the Battery of your 2019 Ford Fiesta Key Fob: stap 5, afbeelding 1 van 1
    • Place the cover back on the fob and snap it into place. Once you hear the click, the repair is complete!
Conclusie
Loren
124 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 319
Altijd: 2,521
