Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
The rechargeable battery in the TI-Nspire CX can lose its ability to hold charge over time. Use this guide to replace the battery and return your calculator to optimum condition.
  1. Unscrew the 2 Phillips #0 screws from the back plate of the calculator.
    • Unscrew the 2 Phillips #0 screws from the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. Remove the back plate using the spudger or by hand. Remove the back plate using the spudger or by hand.
    • Remove the back plate using the spudger or by hand.
  3. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  4. Carefully disconnect and remove the old battery. Unhook the wire from the tab. Carefully pull out the wire.
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the wire.
    • Grip the wire close to the top and pull away.
  5. Plug in the new battery.
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  6. Position the new battery and tuck the wire under the tab.
    • Position the new battery and tuck the wire under the tab.
  7. Replace the back plate and the 2 screws.
    • Replace the back plate and the 2 screws.
Conclusie
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
5 andere personen hebben deze handleiding voltooid.
Jim Kerman
221 Reputatie
1 Handleiding geschreven
Cal Poly, Team 24-2, Green Winter 2015 Lid van Cal Poly, Team 24-2, Green Winter 2015
CPSU-GREEN-W15S24G2
4 Leden
4 handleidingen geschreven
Één commentaar
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 175
Altijd: 7,378
