Ga door naar hoofdinhoud
How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
Wat je nodig hebt
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: stap 1, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: stap 1, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: stap 1, afbeelding 3 van 3
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 2, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 2, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 2, afbeelding 3 van 3
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 3, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 3, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 3, afbeelding 3 van 3
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 4, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 4, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 4, afbeelding 3 van 3
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 5, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 5, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 5, afbeelding 3 van 3
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 6, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 6, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 6, afbeelding 3 van 3
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 7, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 7, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 7, afbeelding 3 van 3
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 8, afbeelding 1 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 8, afbeelding 2 van 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: stap 8, afbeelding 3 van 3
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
Conclusie
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
Lis Cinelli
386 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 51
Altijd: 294
